No Cold Air from Climatronic Air Con - Regassed
I'm asking this as when I bought my car, the AC never got cold, so I'm not sure of "normal" behaviour
An initial VCDS scan showed up
 00229 - Refrigerant Pressure: Lower Limit Exceeded
VCDS showed 0bar of pressure, and so I first assumed that it was a leak somewhere.
I had it into the garage on Monday, and thought whilst there they can check for leaks, and regass if possible.They said the vacuum test came back OK, so gassed it up.
Yesterday morning at 7am I checked using VCDS and it showed Coolant Pressure at 2 Bar, with the engine and climatronic off.
At 5.30 I checked yesterday I checked, and it was at 3.5 bar, with the engine running, and climatronic set to 22.
If I set the climatronic to LOW, I got cool, but not cold air coming out of the vents.
Ambient air temp was only 8c, so does the car realise this, and try to bring the interior up to a minimum temp, the same as it would do if I set it to 22, or should it always give icy cold air when set to LOW, regardless of outside temp?
VCDS now shows no faults on the air con, and the compressor shut off code was 0.
  • Replies 55
  • Views 17.1k
  • No other fault codes. My reasoning was that if it wasn't the pressure sensor then it wasn't going to get fixed as the rest of the parts are too expensive (compared to value of car). For less than £30
  • So how did you know the compressor and condensor were at fault? Or was it just a case of taking bits off and checking?
  • No idea what equipment they used.   They charged £72 for full diagnosis.    I think they did a nitrogen pressure test to identify that the compressor was leaking and screwed.
I had the 00229 fault code. I had aircon re gassed and it worked for a day then blew cool but not icy cold. Yesterday I replaced the high pressure sensor and I am back to icy cold air even with outside temperature at 10c.
Have you got a part number?
I haven't got any fault codes logged currently.
With a crow foot spanner it took all of about 3 mins to fit.
Ok I've done some logging with the engine idling, and the temp set to LO, and fan speed on max.
I assume my compressor is fine as it has shutoff code 0?
Is it likely to be the pressure sensor, bearing in mind no fault codes are logged.
Address 08: Auto HVAC  (1Z0 907 044 H)
17:03:55 Group 001: General
  0.0  Compressor Shut-Off Code
  800 /min  Engine Speed
  0.0 km/h  Vehicle Speed
  00:00  Standing Time
17:03:55 Group 002: Compressor
  0.815 A  Compressor Current (actual)
  0.820 A  Compressor Current (specified)
  1000 /min  Compressor Rotations
  1.2 Nm  Compressor Load
17:03:55 Group 003
  4.2 bar  Refrigerant Pressure
  9.6 %  Radiator Fan Activation (actual)
  0.0 %  Radiator Fan Activation (spec.)
  OFF  Engine Speed (increase)
17:04:12 Group 006
  35.0*C  Evaporator Temperature
  23.0*C  Interior Temperature
  0.0  Left Sunlight Intensity (G107)
  0.0  Right Sunlight Intensity (G134)
17:04:12 Group 005: Outlet/Footwell Blower Temperature
  17.0*C  Left Outlet Blower Temperature
  18.0*C  Right Outlet Blower Temperature
  22.0*C  Left Footwell Blower Temp.
  21.0*C  Right Footwell Blower Temp.
17:04:12 Group 004: Temperatures
  19.5*C  Outside Temp. Unfiltered
  16.0*C  Outside Temp. Regulation
  16.0*C  Fresh Air Intake Temperature
  64.0*C  Coolant Temperature
17:04:20 Group 009: Rear Window Heater (Z2) && Aux. Heater
  OFF  Rear Window Heater (Z2 / Actual)
  OFF  Rear Window Heater (Z2 / Spec.)
  OFF  Aux. Heater Status
  0.0  Aux. Heater Current
17:04:20 Group 008
  14.00 V  Voltage (Terminal 15)
  0.0 %  Dimming (Terminal 58d)
  0.0  Country
17:04:20 Group 007
     Turbine Voltage (actual)
  9.80 V  Turbine Voltage (specified)
  71.2 %  Turbine Load
  13.70 V  Voltage (Terminal 30)
17:04:29 Group 012: Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
  27.0  Current Value
  27.0  Specified Value
  27.0  Minimum Position (Lower Stop/Close)
  223.0  Maximum Position (Upper Stop/Open)
17:04:29 Group 011: Air Recirculation Flap Control Motor (V113) / Potentiometer (G143)
  207.0  Current Value
  207.0  Specified Value
  47.0  Minimum Position (Lower Stop/Close)
  207.0  Maximum Position (Upper Stop/Open)
17:04:29 Group 010
  OFF  Aux. Heater Request
  OFF  Heater OFF
  OFF  Back-Up Lights
  OFF  Front Wiper
17:04:36 Group 015: Defroster Flap Control Motor (V107) / Potentiometer (G135)
  31.0  Current Value
  32.0  Specified Value
  227.0  Minimum Position (Lower Stop/Close)
  32.0  Maximum Position (Upper Stop/Open)
17:04:36 Group 014: Center Flap Control Motor (V70) / Potentiometer (G112)
  221.0  Current Value
  220.0  Specified Value
  231.0  Minimum Position (Lower Stop/Close)
  27.0  Maximum Position (Upper Stop/Open)
17:04:36 Group 013: Right Temperature Flap Control Motor (V159) / Potentiometer (G221)
  25.0  Current Value
  26.0  Specified Value
  26.0  Minimum Position (Lower Stop/Close)
  222.0  Maximum Position (Upper Stop/Open)
17:04:45 Group 017
  3.0  (no units)
  0.0  Roof Status
17:04:45 Group 016: Air Flow Flap Control Motor (V71) / Potentiometer (G113)
  27.0  Current Value
  228.0  Minimum Position (Lower Stop/Close)
That reads like it isn't trying to do anything. IIRC the current draw is what you would expect when the compressor isn't doing anything.
I also have a low pressure fault code that I have cleared. It is going in to be checked and re-gassed on Friday. Can the pressure sensor be fitted without losing the gas out of the system?
Yes. There is a schrader valve (like a tyre valve) under the sensor to stop any gas from escaping.
When the compressor in my car was knackered there were no faults codes. Logging with VCDS showed it was working.
Exactly what I had last year when I had a hole in the condenser and no pressure at all in the system.
Mike
Whoops, that should have been wasn't working.
There was pressure in the system but it didn't change (which it should) and the compressor didn't draw any current.
Can you remember if you had any other fault codes after regassing? Or did it just display the same symptoms as mine?
I'm hoping it's not the compressor as the temperature of the evaporator is different to ambient
No other fault codes. My reasoning was that if it wasn't the pressure sensor then it wasn't going to get fixed as the rest of the parts are too expensive (compared to value of car). For less than £30 it was worth a try and if worse came to worse it eliminated a possible cause. But actually it fixed the issue.
Seems to be quite a common problem on the Octy's. Worth a go rather than replacing condensers and evaporators. Rather spend £30 then maybe have to spend £4-500+ if it's not than spend £4-500+ and find out it was a £30 part.
I will give it a go replacing that.
If that doesn't fix it, then I'll be leaving as is I think.
Is is 17mm crow foot spanner you needed?
Yes mate mine have a lip on them that you have to put over/ under the bolt and slide on so I had to take a dremel to it so that it'll slide on from the side so if you have to buy a set watch out for that. Mine are only a cheap set (£5 flea bay job) so wasn't that bothered. Could possibly get a short stumpy spanner in. I only had to move it a quarter turn to loosen then done the rest by hand.
Where are you based? If local I'd be happy to do it for you.
Edited by Mikek3111
I'm in Lincoln so quite a way.
I'll give it a go at somepoint soon.
Yeah that's a fair drive. Let's us know the outcome.
Back from the garage with the air con now working. However they said that it was empty of refigerent when I took it in. They have done a pressure test for 15 minutes and it passed so they put some dye in and regassed it. They did say that a very small leak would not show up on the pressure test and advised me to take it back if the air con stops being cold again.
I have VCDS but is there any way to read the pressure in the air con system using it? I could then see if the pressure was reducing over time. As the car is only a month over 3 years old I may raise the matter with Skoda although the regas was not done at a Skoda garage.
Richard
Richard
Yes, one of the measuring blocks in the HVAC controller tells you the pressure.
Mine do not give cold air instantly , When I start the car in the morning It took upto 10-20 min. to give some cold air but it is not as cold as it should be .
When I drive on highway with 80-100 km/h then it come to life .
I contacted a local dealer he said that Compresser  needs replacement . He said that a FL Octavia compresser with clutch can be installed in my pre-FL one
And also there are no error code showing on VCDS scan
Having looked into this a bit more I'm not sure now.
Monitoring the AC compressor rpm using the climatronic diagnostic, when the engine is at 1000 rpm, I shows 1300. When at 2000rpm climatronic is reporting 2600 so it rises in line with the engine.
If the compressor is duff would this normally happen?
Yes, as the compressor is attached directly to the aux belt, no clutch or anything so it runs continuously.
