Mk4 golf track car
right here is a link to my track pd130 mk4 golf track project from uk-mkivs seems to be a few more people interested in diesels over here so here is the link
http://uk-mkivs.net/topic/246182-mk4-golf-track-car/
Some of the pictures seem not be working now for some reason so i will post some of the pictures up and any other further progress on here
Get a list of mods and some pictures up on here for us Nick ;)
Had a look but can't see any pictures other than a couple of later ones. Awesome battery relocation by the way :)
Ok here is list of mods on the car:
Engine:
stage 2  hybrid turbo (turbo dynamics)
sachs dual mass clutch kit
miltek turbo back exhuast with decat and discreet tips
pro alloy top to bottom fmic and pipework
RS tuning custom remap
DSG R32 snorkel and modified airbox to suit
pipercross panel filter
Air con rad and pump delete
diesel specific dog bone poly bush
vibratechnics engine and gearbox mounts
running approx 220bhp 320llb/ft
chassis/braking:
R32 front anti roll bar
BC racing coilovers
cast wishbone conversion, super pro bushes with caster bush
quickrack
custom front strut brace
rear seats removed and custom rear brace and b post supports fitted
powerflexed wishbones and anti roll bar
312mm disc upgrade front, 256mm vented discs upgrade rear
EBC grooved discs/ red  stuff pads
body:
modified gti front bumper with anniversary valance
anniversary side skirts
anniversary rear valance
side bump strips removed and welded hole smoothed
boot smoothed beeetle spung latch fitted
fenders rolled/pulled cut and welded
may have forgot a few bits but will keep adding i will post some pics below
10646737_10203947865473031_4334279988677
10653816_10203947864793014_5720910448098
10003981_10203991113874214_3167148797382
10647227_10203991114634233_3162284290496
So these are the custom braces on the car the rears will be coming out as the car will be having a full cage, so if anyone is interested in buying them.......wont be for a while though.loads of other pics that i will post up over the coming days, sorry if these are a bit big unsure how to resize
Nice build, its a brave man who puts a metal battery cover that close to the battery terminals with them exposed. it wouldnt take much in an accident or rear end shunt to push those terminals into the cover and short circuit the battery with resulting explosion of acid. Especially given that a track accident could  involve going rear end first into armco or other obstruction.
the battery is wedged into the cover and the battery is held down with oem battery clamps + extra bracing, there is some added foam padding now internal of the top lid and on the underneath of the lid itself, but to be fair if that battery moves or that cover bends im in serious trouble as i would of had a major accident!
  • 3 months later...
So not posted for a while, and to be fair i've not done a lot on the car apart from some custom fabrication work that i can't really take any credit for, however i've now stepped up my interest again after seeing Alex's(alex_e) car and the motivation and enthusiasm he has for it.
So here are a few pics of the fabrication work, and should hopefully be fitting the oil cooler from the group buy along with some LCD gauges in custom wrapped pods:
  • 6 months later...
So i thought i would give an update on my car, a few things have been fitted since the last post here is an update on parts fitted:
Engine:
GTB2260vk, tubular manifold and 3" downpipe
Xman uprated dual mass and kevar disc (2.5 tdi pressure plate 400lbft rated)
custom single pass fmic and custom pipework
Hidden-power remap
Custom alloy airbox and pipework with bonnet intake
AEM dryflow cone filter
4 bar map sensor
Prosport boost, oil temp/pressure and EGT gauges
Battery relocated to boot
unknown bhp to date circa 230/40bhp firad nozzles to be fitted soo
chassis/braking:
BC racing coilovers
quickrack
rear seats removed and Roll cage fitted
Racing steering wheel with quick release
body:
Edited by bagnall007
So firstly since last post I have fitted gtb2260 with tubular manifold and an uprated clutch from xman to handle the power. The boost isn't fully wound up yet but clutch feels good/OEM no problems of yet but it's early days.
Removed radio and top air vents for this custom setup but want to make it neater just not sure how to go about it really need somewhere else for the rear screen heater and hazard light switch as it looks poor as it is
Sent from my SM-G920F using Tapatalk
Also the engine is bay is getting close to complete with a lot of custom alloy workff665f9a97d6f0afe7b89317592245ee.jpg
Not sure if the custom air box will make any difference but i think it looks cool.
Battery has been relocated to boot and used some 50mm welding cable to do this as it's very flexible and so fairly simple to run in once through the firewall
Seem to have lost pics of battery boot install so will update at a later date with pics.
Racing steering and quick release from Nrg
This was really simple to do and I disabled the airbag via vcds. Wheel has a horn on it and auto cancel indicators still work.
FMIC installation took a bit of time a lot of custom pipe cut and then welded up by a mate nearby but it all came together well in the end and now have a single pass fmic instead of dual pass which I had before which I don't think flowed aswell
Latest development is custom built roll cage to be fitted very soon. A few pics of this
Main hoop sprayed rear strut bar to go in , hoop to strut bar needs welding up and bars from hoop to custom pads in front foot Wells to go in more pics to follow
