steering wheel badge
6 hours ago, S00perb said:
Pity - I don't use facebook
I'll get you some contact details if you wish
  • Replies 60
  • Views 30.2k
  • Only problem I see with this method is you don’t know what will happen to the badge in a deployment situation as part of the structure has been removed. Best way is to fit the OEM cover instead.
  • The point is you don’t want to modify the cover at all just in case something goes wrong when it rips open.
  • Sorry for the delayed reply.   I rebadged the whole car, just like you, but got into SERIOUS problems with the steering wheel logo.  Essentially, it's bound to the airbag cover with two metal tongue
That would be good of you, thanks
On 27/06/2015 at 16:45, mbirkely said:
Hi, Yes the one on the lift side is from at 2006 Octavia. Others use this airbag to. fx. fabia Around same year. The one on the right os from af Faceliftet Octavia, also used i fabia an Superb pre facelift.
Some friend of mine have made a little guide. It is in Danish. (sorry).. But you get it all from the pictures.
It involves some drilling af gluing. The one on th left it clerly the easiyst to change. And it is because that one is bending ind instead og out lige the facelift one.
(This guide is all on your own. And at your own risk) ;)
https://dl.dropboxusercontent.com/u/33318666/Montering%20af%20nyt%20airbag%20logo..pdf
Is this guide still available? 🤔
yes.
I have done it with succes 2 times.
But remember - This guide is all on your own. And at your own risk.
Montering af nyt airbag logo..pdf
On 26/06/2019 at 14:06, Danton said:
Tag! Perfect opportunity to learn Dansk ;)
And where do I buy an OEM cover with the new logo? Only the Citigo got this one right? But it is without the chrome trim. Plus cars-equipment sells modified covers and modified emblems. I found an emblem for like €15,- and could modify it without modifying the cover too much. I don't want to drill a hole that large. :D
The cover I bought was brand new from the manufacturer of the bag unit at the above link.
Edited by 3T51704x4
  • 6 years later...
Someone who still has this guide, cause the dropbox is 10 years old?
