help with felicia abs pump
Recommended Posts
Hi any one help me out on witch pipes go where on the abs pump brake outputs. Don't fancy testing them and stopping in a spin... so far every think else has been fitted on my pick up 256mm up front on abs hubs and abs rear drums for now rear disk later.... and I believe I don't need to run a load valve am I right.
Edited by uma1998
Link to comment
Share on other sites
Haynes Manual does not show abs only wireing side I need to know the hydraulic out puts are for the brakes don't fancy ending up spinning O in road...
Link to comment
A fellow member having ABS should take a photo of their ABS installation.
Note: ABS installation is a very special job. Not for DIYers. The slightest mistake and you'll end up dead. Which I guess it's a bummer...
Edited by RicardoM
Link to comment
It's a 6 port one vw part would you believe.. its got 2 in and 4 out... I belive it's piped like this. From where plug on module (bulkhead end) is as 1 front left then 2 rear left then 3 front right then 4 rear right. Wireing side is all done and tested on vag com. Am I right that I don't run a load valve repipeing all pipes....
Reson for abs is I had a audi pull out on me at 50mph and killed the last felicia was pinkskuds old pink one
Link to comment
Looks like I got to change the pipes around what a..... thanks for you help tom your the man.. another one how can I fix the pipes back as some clips broke and can't get new clips from tps....
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
