First Time Scan Help with faults please
Hi Guys bought VCDS from Gendan a company local to me in Swansea. Scanned my car earlier and have a few faults stored. If someone can help sort out these issues I would be very grateful.
Here is the list...
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
www.Ross-Tech.com
Sunday,07,June,2015,13:52:16:49176
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBEF21Z468069605   Mileage: 196730km-122242miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Z0 907 115 A    HW: 1Z0 907 115
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H10---    Serial number: SKZ7Z0E3299505
   Coding: 0203000318070060
   Shop #: WSC 66565 257 00032
   VCID: 336559EE52F570B9A3D-8066
2 Faults Found:
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 196715 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 77.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.938 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 196715 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 77.0°C
                    Temperature: 45.0°C
                    Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 73430 790 00000
   VCID: 71E993E6686902A9911-8024
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B7571CE7AA5B8F97BD-806E
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003743459
   Coding: A98C1F031004140000110D000000000000197F075C
   Shop #: WSC 73430 790 12345
   VCID: 2B55418E8AC52879EBD-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
1 Fault Found:
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 172614 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.85 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: Q4 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD03389Q
   Coding: 0020788
   Subsystem 1 - Serial number: 6332MSME0C710420/
   Subsystem 2 - Serial number: 6342MSME0B7A2446G
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000012
   VCID: 76E3A0FA01072591443-8023
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 C
   Component: KOMBIINSTRUMENT VD1 3562
   Coding: 0003401
   Shop #: WSC 00336 002 1048576
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 310111F1003300
   Coding: 350000
   VCID: 306F56E263E34BA1DEF-8065
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3562
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H06 2684
   Revision: AB001001    Serial number: ZZZZZZZZZZZZZZ
   Coding: 000002000201000300
   Shop #: WSC 00953 210 43597
   VCID: 2E53489A79D75D51CC3-807B
2 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 112
                    Reset counter: 251
                    Mileage: 196520 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:13:10
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 34
                    Reset counter: 251
                    Mileage: 196520 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:13:20
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000756
   VCID: 366360FA41876591843-8063
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            012 - Electrical Fault in Circuit - Intermittent
00100 - Drivers Interior Locking Button (E308)
            008 - Implausible Signal - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 34675AF257FB7781BA7-8061
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D8F0F481F861004CC
   VCID: 79F9ABC630194AE9291-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000756
   VCID: 377D6DFE468D9C999F5-8062
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 251
                    Mileage: 196520 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:13:10
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 34
                    Reset counter: 251
                    Mileage: 196520 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:13:20
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 326B5CEAADEF79B1A8B-8067
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
End-------------------------(Elapsed Time: 01:41)--------------------------
Love from Maj xx
sorry to be blunt but what line are the DTC's lol
The very first number after the line “# Faults Found" (I will highlight a couple in your scan in RED for you).
Personally, I'd clear the errors and re-scan after a day or so. Sometimes things happen, they get fixed and no-one clears the codes. New owner finds codes and thinks something is wrong.
The Scout was full of codes when I picked it up.............due to the battery being replaced, and the dealer not clearing them. I cleared them all and they've not come back :)
Seems to me your scaring the pants off yourself  'VRS_MAJ with your new VCD...suggest put it back safely in the box and wait until there is a real/ obvious malfunction to use it...LOL
Had the car 3 yrs, been scanning ever since and the errors are radio and engine faults. They always return after deleting the wing mirrors are recent. Just want to completely sort out the problems lol. Bought my own VCDS as I dont like pestering people to use their own lol.
I HAVE OCD
Maj xx
