Air conditioning, does it work at settings 1 & 2?
Hi again all,
I've never noticed this before on my Fabia but today as it was hot and the car had been sitting in the sun i put the a/c on but i had to turn the fan to position 3 or 4 for the a/c switch to light up. I'm certain it worked on positions 1 & 2 before or did i imagine that?
Is this normal or is there some sort of issue brewing?
Mine works on 1 & 2
Does the blower work on positions 1 and 2 without the a/c on?
I'm pretty certain it does but come to think of it over the winter i did think that i was having to use 3 or 4 more often than 1 or 2
Mine used to work on one but not anymore,has to be 2 or higher, strange
It's usually the fan resistor.
That's what i'll look at first. Thanks for the video
It's quite a common thing to fail.
In your case, if your blower doesn't work on 1 and 2 without the a/c on then that's probably what it is. They also commonly fail on position 1 only too.
Check to see if the blower works on 1 and 2. If it doesn't it will be the heater resistor which is a common failure. My air-con didn't work on speed 1. I then noticed with engine off (but ignition on) the fan wasn't working, but was on 2,3 and 4. I changed the resistor and it now works
Just checked, 1 and two aren't working, that explains it.
Yet again on here, ask a question and get an answer. Cheers guys, it's very much appreciated.
Thanks  :thumbup:
If you don't know when it was changed, "do" your pollen filter too. As reduced flow over the resister is one way of killing it.
Cheers for the tip, i don't know when it was last changed so i'll do that too
Very true :thumbup:  The resistor relies on good air flow to cool it.
