MY12 Elegance work log - with part numbers and coding
If you got puddle lights in the mirros then you might have the right door modules as well. I've got puddle lights, i checked the modules and they where the right ones for power folding. Now i just need to source the parts.
Claudiu2s if your successful keep me in touch, I will do the same, good luck sourcing the parts.
I've texted you 07702033841. I can meet you wherever is best for you on Saturday.
Claudiu
Claudiu
Please ignore this. I've tried to edit/delete it and isn't working. Probably because I posted it from my phone hence the error. This was meant to be a private message for somebody. Sorry
Edited by claudiu2s
No problem!
Hi langers2K here is my autoscan of the door
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
Component: Tuer-SG         009 2120
Coding: 0000756
Shop #: WSC 73430 790 00209
VCID: 489EDDFB3B6C5D0234-801C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 479CDEC73672527A3D-8012
Will the mirror dip retrofit work on mine? Also can you share the details of the parts required for the mirror dip please?
No
These basic ones support the mirror light but not Mirror dip, Folding or Auto dimming mirror glass
Change to one ending S on the passenger side
and AA or AF on the drivers side if you want Folding
No
Thanks Eddie-NL
Also I wanted to make an addition to enabling Voice Control / PTT in VCDS. I wasn't able to get PTT to work even after checking Bit 3 in 16-Central Electronics. So after a bit of searching I found the following settings to work in the end.
Apparently you have to go into 37-Navigation and uncheck 'Speech dialog system'.
16 - Steering Wheel
Byte 1
- Bit 3 "Multi-Function-Steering-Wheel (MSFW) with Push-to-Talk (PTT) Button installed" (Check)
Do-It
37 - Navigation
Byte 10
- Bit 7 "Speech Dialog System (SDS) disabled/blocked)" (Uncheck)
Do-It
Edited by singh946
  • 10 months later...
Couple of minor updates.
Updated/flashed ABS from 1K0 907 379 BJ (SW:121) to 1K0 907 379 BL (SW: 152).
Replaced BCM with 1K0 937 087 AL.
Updated/flashed BCM from 1K0 937 087 AL (SW:0771) to 1K0 937 087 BA (SW: 0903).
Updated/flashed CAN gateway from 7N0 907 530 BG (SW:1674) to 7N0 907 530 BL (SW:1682).
Mostly just experimentation rather than trying to add/change anything :)
