Fabia can bus
Hi, I have a September 2014 Fabia, I tried fitting a 2015 VW RNS315 with Bluetooth, all seemed to work ok except the ignition did not seem to control it, I went away for five days and came back to a flat battery,
Is this a coding issue or do I need a different canbus? - if so which one, I have controls on the Left hand side of the steering wheel for radio control, will these work with a 315 radio?
Thanks for readings
What radio did you have installed before?
Hi,it came with the standard "swing" radio.
One other thing I noticed was the nav voice instructions were a little late - presumably no speedo feed.
Thanks,
Mike
Should be a straight plug and play. I did the same thing. Replaced my swing for a rns 315. Plugged it all in works with no issues. Might be worth unplugging it and re seating the connection. Other than that I don't know.
i have the rns 510 and it need some adjustment and coding not sure with the yours.
