Immobilizer issue!
This might work .. as a temporary fix .. to get the car going.
Bought this didnt work, i presume as the key is fine. The box its self does something. After the 20 seconds per instruction you here the fuel pump... so i guess if you have a bad transponder this will work :)
 - So my issue, some other thoughts.
My traction/ esp light is on, yet when turning ignition on, pressing the button does not turn it off/ nor does the rear heated window button next to it... are these together on a relay??? Would a traction / esp fault cause the immobilzer to act up ?
Im clutching at straws here, before i admit defeat and am forced to pay for recover to be ripped off by Skoda main dealers :(
  • Replies 121
  • Views 21.4k
  • Those ebay immo defeat boxes should be made illegal, one reason why you should seriously consider altering the OBD port on your car to a non standard configuration so these boxes do not work and savin
  • Literature
  • FromTheDarkness
    FromTheDarkness
    fck it just bought a plug and play ECU with immo deleted ....
Is it possible ive fried my fuses and relays including immo relay, when ive cleaned the earth points/ disconnecting ecu?
It seems i have a few electrical issues, which i didnt have prior to this:
5 Faults Found:
17564 -  Manifold Pressure Sensor (G71): Open/Short to Ground
            P1156 - 35-10 -   - - Intermittent
18061 -  Please check DTC Memory of ABS Controller
            P1653 - 35-00 -   -
17978 -  Engine Start Blocked by Immobilizer
            P1570 - 35-00 -   -
18043 -  Powertrain Data Bus: Missing Message from A/C Controller
            P1635 - 35-10 -   - - Intermittent
16955 -  Brake Switch (F): Implausible Signal
            P0571 - 35-00 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: 6Q0-907-37x-ABS.LBL
   Controller: 6Q0 907 379 H
   Component: ABS/ASR 5.7 FRONT   V30
   Coding: 00188
   Shop #: WSC 13765
   VCID: 42F7C90B5D97
1 Fault Found:
01314 -  Engine Control Module
            49-00 -  No Communications
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F297D9CBADB7
3 Faults Found:
01596 -  Motor for Outside/Recirculated Air Flap (V154)
            30-00 -  Open or Short to Plus
01299 -  Diagnostic Interface for Data Bus (J533)
            79-00 -  Please Check Fault Codes
01317 -  Control Module in Instrument Cluster (J285)
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
   Controller: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 25738
   Shop #: WSC 13765
   VCID: 3B09B4EF3A7D
10 Faults Found:
00511 -  Selector Lever (E313)
00778 -  Steering Angle Sensor (G85)
01324 -  Control Module for All Wheel Drive (J492)
01598 -  Drive Battery Voltage
            07-10 -  Signal too Low - Intermittent
00966 -  Fuse for Blinkers (S151)
            37-10 -  Faulty - Intermittent
00900 -  Fuse for Signal Horn (S194)
00969 -  Fuse for Heated Rear Window (S41)
00903 -  Fuse for Heated Outside Mirrors (S196)
            27-00 -  Implausible Signal
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 601 A
   Component: 11 AIRBAG VW51      0008
   Coding: 12593
   Shop #: WSC 13765
   VCID: 1E4F5D7B89AF
No fault code found.
Address 17: Instruments       Labels: 6Y0-920-xx0-17.LBL
   Controller: 6Y0 920 970 Su
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 28401
   Shop #: WSC 13765
   VCID: D6DF855B211F
   TMBWU46Y043917575     SKZ7Z0C2110458
1 Fault Found:
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Component: 31 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 13765
   VCID: F093D3C3A3BB
4 Faults Found:
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre ssu
   Component: e 17 eingeben
   VCID: CFD1703F1EC5
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 44: Steering Assist       Labels: None
   Controller: 6Q0 423 156 S
   Component: LenkhilfeTRW        V260
   Coding: 10120
   Shop #: WSC 13765
   VCID: 3FF1C0FF2E65
1 Fault Found:
Address 46: Central Conv.       Labels: 6Q0-959-433.LBL
   Controller: 6Q0 959 433 E
   Component: 33 Komfortgerát     0002
   Coding: 00066
   Shop #: WSC 13765
   VCID: 3D0DBAF72469
End
Vag Commander is what you need. You can disable the Immo and retrieve the code for future use.
The box i used disabled the immo
But if the dash has lost coms / or immo code to the ecu then it wont work.
Where is the relay for the dash / ECU ?
There are plugs in the bulkhead (behind the dash) which connect everything up. Have you recently hit a bump or installed cruise control?
No just disconnected the ecu to clean the contacts and clean all earth points in the engine bay. Then car has a million faults and immo blocking engine start :(
All the cable seated in the ECU correctly? No bent pins?
Is the earthing points all fitted correctly?
Checked the fuses on top of the battery?
Yep all done
Sounds stupid, what have you used to clean the contacts?
electrical contact spray.
What prompted you to do this originally, what were the original faults?
this fault :
            49-10 -  No Communications - Intermittent
You definitely have either a broken wire or ECU fault.
The dash isn't communicating with the engine ECU, which is likely the reason for the non start, also the Gateway coding needs to be refreshed, recode it using the same code as it thinks that it's an all wheel drive automatic.
What is the coding on Engine [01] using VCDS?
What do you mean? Your question doesn't make a lot of sense.
The coding, 00102 or 00105? See if the ECU is on the correct codebank.
Don't think it makes much difference in this case, because if the coding was wrong the glowing light would illuminate and flash.
Is this what your after?
Address 01: Engine       Labels: 038-906-019-ASZ.LBL
   Controller: 038 906 019 LA
   Component: 1,9l R4 EDC 0000SG  4904
   Coding: 00102
Well, the coding is correct so that's not an issue.
I'm still working on the wiring has a break somewhere. Have you left the battery off over night to see if this changes anything?
Not over night but ive had the negative off for nearly a hour, then i connected the positive and negative together for 40mins.
didnt change anything.
So i plan on going over the ecu wiring .. its hard to see if there is a connection problem there.. but will check again... then im going to get into the relays ... again not to sure how a inspection can see a problem.
I was also wondering would a dash wire check/ removal do anything?
You could drop the Central Control module and the relays and see if there is anything loose. I has an issue similar to this and it appeared after hitting a pothole. The fault for me was the white plug at the bulk head had become loose causing the clocks not to talk to the ECU and giving me 30 faults and errors.
I think your issue must be engine side as that is the only wires you have moved. Something must of be rubbing somewhere in the loom and you unplugging has caused the wiring to separate.
Of course, all this is only theory...
Where to start ... the ecu wiring is tight and not far into the bulk head ...
It is wrapped nice and tight, but chaffing should be noticable.
Im more incline to think there might be loose connections into the socket. There is no outer damage on the wrapped loom. i checked that.. but internally unknown.
Darkness where is the original thread that led into this? Seems to have dissapeared been deleted? I'm sure you mentioned something about your battery? May be wrong or have it mixed up.
