Immobilizer issue!
Darkness where is the original thread that led into this? Seems to have dissapeared been deleted? I'm sure you mentioned something about your battery? May be wrong or have it mixed up.
No mate this is the original post, but the third page :P
  • Replies 121
  • Views 21.4k
  • Those ebay immo defeat boxes should be made illegal, one reason why you should seriously consider altering the OBD port on your car to a non standard configuration so these boxes do not work and savin
  • Literature
  • FromTheDarkness
    FromTheDarkness
    fck it just bought a plug and play ECU with immo deleted ....
So ive spent all day, checking wire/ fuses/ relays.
All wiring in the engine bay is sound, as are all the connections in the ECU, and all earth points are good.
I disconnected the battery and left postive and negitive together over night.
Ive got everything back, the engine immobiser error has gone ....
How ever, i have no comms with the ecu at all   :p
Here is the error log:
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 03: ABS Brakes       Labels: 6Q0-907-37x-ABS.LBL
   Controller: 6Q0 907 379 H
   Component: ABS/ASR 5.7 FRONT   V30
   Coding: 00188
   Shop #: WSC 13765
   VCID: 42F7C90B5D97
1 Fault Found:
01314 -  Engine Control Module
            49-00 -  No Communications
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F297D9CBADB7
1 Fault Found:
01596 -  Motor for Outside/Recirculated Air Flap (V154)
            30-00 -  Open or Short to Plus
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
   Controller: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 25738
   Shop #: WSC 13765
   VCID: 3B09B4EF3A7D
5 Faults Found:
01598 -  Drive Battery Voltage
            27-00 -  Implausible Signal
00511 -  Selector Lever (E313)
00778 -  Steering Angle Sensor (G85)
01324 -  Control Module for All Wheel Drive (J492)
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 601 A
   Component: 11 AIRBAG VW51      0008
   Coding: 12593
   Shop #: WSC 13765
   VCID: 1E4F5D7B89AF
No fault code found.
Address 17: Instruments       Labels: 6Y0-920-xx0-17.LBL
   Controller: 6Y0 920 970 St
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 28401
   Shop #: WSC 13765
   VCID: D5DD82573C19
   TMBWU46Y043917575     SKZ7Z0C2110458
1 Fault Found:
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Component: 31 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 13765
   VCID: F093D3C3A3BB
4 Faults Found:
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre sst
   Component: e 17 eingeben
   VCID: CEEF6D3B19CF
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 44: Steering Assist       Labels: None
   Controller: 6Q0 423 156 S
   Component: LenkhilfeTRW        V260
   Coding: 10120
   Shop #: WSC 13765
   VCID: 3FF1C0FF2E65
1 Fault Found:
Address 46: Central Conv.       Labels: 6Q0-959-433.LBL
   Controller: 6Q0 959 433 E
   Component: 33 Komfortgerát     0002
   Coding: 00066
   Shop #: WSC 13765
   VCID: 3D0DBAF72469
Does it seem the ECU is goosed?
There is now no reponse from 01 engine scan ... :(
:D good luck.
:D good luck.
It still wont work if the error is with the dash code .. i think??
Yeah I'd think so also, worth a shot of your not getting communication though.
The no come will be because the battery is unplugged. You can get the same when flashing the Ecu.
Shame I didn't read this sooner, could have sent an Ecu with immo off for you to try :(
It wasnt unplugged   :(  There are no comms, and vcds cant even read from the ecu
Thanks for the offer, but if there are bigger issues than the ecu, i wouldn't want to fry yours also :p
But to be honest im 99% happy that ive checked all the usual issues, i spent 6 hours going over wiring/ earth points/ fuses and relays.
Have you re coded gateway as yet? Wont get rid of all the problems but thinking its a 4x4 auto isn't going to help matters.
no not sure how ...
And it was working fine then stop working one day?
Sorry for my ignorance but is this good practice?
Only if they have been discounted for more than a few hours. Capacitors hold electricity for x amount of time so that needs to have drained before you touch them both together again.
It's done to make sure every last bit of juice has been used up. I've never done it personally, don't need to.
I believe the op did this before his ecu went crazy. Possible cause.
Op please correct me if I'm wrong.
your wrong :p
everything was working fine with the car.
One day i performed a vcds error scan
and i got a "no coms" error
I checked wire/ battery/ fuses/ etc, the error persisted.
I was told to check the ECU connection pins
After doing so ... car cut out after 2 seconds, and there was a engine block immobizer error logged .
The only thing i did that i shouldnt is, disconnecting the ecu with the battery connected, and cleaning the earth... these are the only possible ways ive goosed the ECU.
Only then did i do the positive and negative together over night. Id already tried for 40mins, and was at the point of what else can i try.
It sounds like the fault lies in the plug to the ecu however it could be the loom where it goes down the inner wing has got water damage and disturbing the ecu may have finished it off. multimeter time to check the harness back to the bulkhead before spending any money.
I'd have taken it to an auto electrician ages ago :D
Taken - is the problem :P
If the new ECU doesnt work, i will have to buy brake down recovery and then find a reputable auto electrician i guess :(
Just tow it.
Or a recovery company will take it.
Anyone with a flat bed or trailer will do.
Mobile auto electrician?
no not sure how ...
19- gateway
07 - code control unit
Enter in the coding
Save
It will get rid of half the faults at least as gateway is the diagnostic interface and currently it thinks your car is a different spec to what it is.
It was a common problem at one point when things have been unplugged, gateway defaults to a random spec.
19- gateway
Enter in the coding
Save
enter in the coding? whats that? what coding :P
enter in the coding? whats that? what coding :p
The dash isn't communicating with the engine ECU, which is likely the reason for the non start, also the Gateway coding needs to be refreshed, recode it using the same code as it thinks that it's an all wheel drive automatic.
Fordfan already posted an age ago, and he's not wrong.
yes both are not wrong ... and it will get done, but it will not fix the ecu :P
As for the dash bit, if thats what you mean... that was before second ecu wiring inspection etc, now there are no coms at all, and vcds cant scan engine block 01 at all, sooo ... Im waiting on a new ECU and if it works its the ECU that was failing then died, if the new ECU doesn't work then its wiring, probably wiring down the inner wing as suggested above.
