Immobilizer issue!
Out of interest can you access with the engine ECU if you force K line communications?
  • Replies 121
  • Views 21.4k
  • Those ebay immo defeat boxes should be made illegal, one reason why you should seriously consider altering the OBD port on your car to a non standard configuration so these boxes do not work and savin
  • Literature
  • FromTheDarkness
    FromTheDarkness
    fck it just bought a plug and play ECU with immo deleted ....
No idea what K line is sorry ...
How ever update, New ECU arrived and fitted .. car starts and runs and all error codes are gone.... But lol ....
I requested EGR delete,with the immo defeat... and the issue is i have no accelerator :P
Ah nice mod, you have a throttle delete :D
yes its the future in cheap insurance .. forget the black box
one step forward, two steps back  :notme:
Its sorted :) i have a working car... first time in 2 weeks:P
What was it?
What was it?
No idea, i checked the pedal sensor, used contact spray on all connections under the dash, removed battery and ECU, and refitted ....
So one of them sorted it :p
I must say the seller of the ECU, as been extremely helpful, replying to all my "help" questions :p
This is the ECU i bought: http://www.ebay.co.uk/itm/271957523461?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
trying to sort this..
the above is set to 00014, so is correct. instruments (17) is set on 28401.. is this right im confused on the last/ bottom option that equates to the 1 in 2840(1) also ABS is 00188 which there isnt a option for..either 00044(manual) or 00045 (auto)
it's working, right? why are you ****ing about with the ecu? again?!?
Ive read that but i dunno what option it uses for the last set im guessing CAN 1 ?
also the 4x4 issues are in the central electronics and ive no idea what i have / dont. do  you know the spec for the fabia vrs?
central electrics currently 25738 - this is the issue
Both codings look ok to me.
No, I don't have the spec. for the VRS.
 I changed central electrics from 25738 to 17544 was nt 100% but im not driving a 4x4 now lol
Where did you get the values to calculate that coding?
found it :
Software Part Number 6Q?-937-049-B and before:
  • +00001 = Trailer Hitch installed
  • +00002 = Trunk Lid Remote Unlocking installed
  • +00004 = Electric Load Management active
  • +00008 = Interior Light Control
  • +00016 = 4-door Chassis
  • +00032 = Heated Front Seats installed
  • +00064 = Heated Front Windshield installed
  • +00128 = Heated Mirrors installed
  • +00256 = Headlight Washers installed
  • +00512 = Rain Sensor installed
  • +01024 = Trunk Lid Remote Unlocking impulse driven
  • +08192 = Rear Windshield Wiper with Comfort Function installed
  • +16384 = Electric Fuel Pump Releay installed
2+8+128+16384 = 17544
found it :
Mine is:
8192+1024+128+16+2=9362 checked with VCDS module 09.
I suspect yours is the same plus the fuel pump relay which is 25746, unless your interior lights don't dim in which case it's 25738  :D
Mine is:
Mine is:
oh yes i didnt realise i had "comfort" rear wiper :P
Dont we have "interior light control"  = +8 ?
oh yes i didnt realise i had "comfort" rear wiper :p
I think that's only the elegance, mine is the comfort spec, I think the VRS is basically comfort spec. because it doesn't have electric rear windows or heated seats as standard either. I don't know about the other guff, maybe heated windscreens and rain sensors were really high cost options that no-one went for.
ok mate ive reset mine to  25746
Im wondering what interior light control actually does .. mine is just the standard spec throughout.
Maybe it's the fabled 'mood lighting' that gets all the sad chavs pitching their tiny tents?  :sun:
