gtb2260 build fabia vrs
Is the vnt lever the same?
  • Replies 56
  • Views 15.4k
  • Bit of an update got calipers powder coated and fitted ended up fitting 8mm spacers to gain clearance [url=http://s567.photobucket.com/user/patrickferguson20/media/Mobile%20Uploads/20160312_1237
  • Intercooler done today waiting on ibiza slam panel downpipe flange lined up and silencer ready for welder and pictures of projectors in daytime
  • bit of an update got 2.5" downpipe ordered for tubular manifold fitted pd160 intake and found a fuel cooler in the scrap yard im gunna use perfect size to hide away just need to get some braided lines
No the leaver looks longer to make it pull on a better angle more of an 90 degree I should av took pictures, when I coupled the vacuum to them I could get the leaver to hit the stop screw on the new turbo but on the old turbo I could never get it to reach the stop screw because of the angle of the lever
Interesting. As part of the vacuum conversion the gtb lever is removed and normally the vnt17 is welded on.
Interesting build and good read thanks.
I notice you are cutting the downpipe, did the Profidiesel downpipe not align properly?
Downpipes a good fit he just tacked the flange on as he couldn't predict where it needed to be happy with it tbh good quality
My original gtb2260 was never hitting the stop screw so that might be the reason ,it looked a total different design on the new turbo unless the higher blades on the billet wheel help it build boost
It'll be interesting to see some logs to see what in comes in like compared to other people's standard 2260's.
Il get logs posted when I've fitted injectors and got some stronger headbolts don't want to lift the head looking to run 2.5bar of boost
Where is the side light now?
Hides just behind the projector but gives a nice glow
bit of an update fitted some 42 designs shifter bushes today made the gears alot tighter more precise and fitted a mk4 golf n75 valve as my old vaccuum box was buzzing and causing some boost issues still need to fit some head bolts and my injectors
Got any more information on the golf n75 mod?
Does it remove the need for the vacuum reservoir?
Great read so far mate :)
A link or a write would be handy. My box went so I had to get another one but I don't fancy it's chances in the long run. Any help would be great :)
All I did was solder pins 5 and 3 to the plug of the n75 valve from a mk4 golf but just twist them togather first to make sure it work then I just just solderd them and used some heatshrink around the wire where the join is pretty much all I did I disconnected the vacuum ball aswell noticed no difference in running hope that helps :)
Edited by fergy
bit of an update got a good deal on some 312mm ap 4 pots of an ibiza and helix smf paddle clutch going to get the disk repadded before it goes in though
Be ready to build up your left leg muscles lol. I love my paddle clutch, takes a abuse all day long. Is it a 4 paddle one?
Just read through all of this. Nice work so far pal, coming along nicely. What kinda figures are you expecting from it?
its 6 paddle thinking of getting cg motorsports to repad it am hoping to crack 300bhp but il be getting a cam sooner or later though, want to try a keep smoke levels down but il be doing all the mapping myself so il just keep going untill the smoke starts dont want a smoke machine
  • 4 months later...
no posted in a while but heres a log of the boost curve of a gtb2262vk still mapping it at the moment its not finished but its an idea of how a hybrid spools
after looking at cams for quite a bit decided to get a dbilas 280° 10.5mm lift new cam off them hoping this will allow me to break 300bhp
Very impressive!
Hope it works out.
What software are you using to do the mapping? do you have access to professional stuff or using a free one?
Just curious as I have been looking into this sort of stuff, Thanks
just a mpps off ebay and use winols to modify the file
Thanks for the reply, I looked at Winols but thought the paid for version was needed to actually modify/save the maps rather than the test version, could be wrong as I found their website pretty hard to navigate!
Are you going to fitting stronger double springs for the valves with this camshaft? And do you know if it's cut from a chilled cast blank or steel blank? Will be interesting to see how this pans out.
