Fabia 2 monte resr disc conversion
Thanks might just pop in a few breakers tomorrow :)
All i need then is a new handbrake cable right?
  • Replies 72
  • Views 8.8k
  • I for one will be watching this with interest, as this was a mod I intended to do to my Monte (for the asthetics) and because they wouldn't sell me a VRS with a Monte body kit. but as many people have
  • Outofthi5world
    Outofthi5world
    They look great when you paint them. I sprayed them with Hamerite smooth black.
  • I see all the keyboard warriors are with us today, the car is a 1.6 tdi not a 1.2 as stated by some users,the abs pumps etc are all the same, if it needs coding Ivan do it with my vagcom. That's for a
You will need pair off a fabia 2 vrs, everything bolts up, brake pipes fit from the drum beam, you will need the complete beam with the steel brake pipes up to the beam flexis. If you need any info how to do it let me know and I'll help as best as I can
Tidy thanks ive got a large shopping list to go through recently lol
Yeah I'm going to do a 312mm front conversion aswell just trying to find some hubs as mine was a 75bhp model with the FS3 silly front calipers
Any chance you got any photos during the process? Would be good to have a tech guide- for an extra £80 over new brake drums it'd be worth going for.
I did a few pics while I did it
I've now got the hubs and calipers for a 312mm front disc conversion now !
Front 312mm disc conversion started today, one side done
Well, you're committed now. Can't leave it like that! :D
Yeah I know, good job I've got the mk2 sleeper
I fancy a rear disc conversion. What is it with new cars with drums! My cactus has em too.
Cost cutting I believe.
Edited by 32KOFDATA
Cost cutting and the fact they just aren't necessary. I was out breaking a lot of track cars at Snetterton in the Monte with standard breaks.
They are necessary - drums look dreadful ;) !
Well that's it brake upgrade done, 312mm on the front now and it stops so much better and looks like it should do in my opinion. Rear discs and bigger front brakes that fill the wheels properly
I'm glad I optioned esp... it gave me not only the esp system but discs on the arse-end too! If I remember rightly, it was not too expensive an option too as they do it right from build! Just a few hundred quid and you know its gonna be working properly. (Not a Monty, by the way, just a Greenline. Reading this out of interest).
Edited by mrgf
Rear discs were only standard on vRS and Greenline Fabia models which were sold in the UK.
ESP didn't add rear discs to a model that came with rear drum brakes. My ex opted for a ESP on her 2011 1.6TD (105) SE plus but that still came with rear drum brakes.
Somebody else can confirm this but I believe in some countries the Monte Carlo did come with rear discs as standard though.
Mine is an 09 Greenline, not the later Greenline 2 from the facelift. The early ones did indeed come with rear drums as standard, EPS being an option that changed them to discs along the way! I know as I optioned it from build.
  • 6 months later...
Mighty Car Mods have produce a video on doing a drum brake to disc brake conversion.
So this should give an idea what is involved fitting discs to a Fabia.
Edited by AJR77
If only it was that simple on a Mk2 Fabia that comes with rear Drum Brakes as standard!
  • 1 year later...
Resurrecting the thread, I have seen a couple of montes in France over the past couple of weeks, white and red. All have the black plastic door strips which I don't like but the rear disks which I do. Seems odd uk cars have the drums as standard??
MkII's that is.
Edited by mgcvk
On some options, it will be up to each individual sales territory official importer to specify which options get fitted to which model variants, and also which factory customer options will be available.  Also, the local conditions, ie ambient temperatures and topography will influence their decisions as well as impact on sales.
It is purely aesthetic I suppose. Disks just look smarter with gappy alloys. Maybe it is incentive for the uk enthusiast to go vrs? My drums are painted black at mo which I know won't last. If the wheels ever get powder coated then will get drums done black. Quite fancy wheels in gold.;)
