Annoying rattle
Anyone experienced an annoying vibration coming from the front of the car (seems to be behind the dash) at about 1300 - 1400 rpm?
Car is a 2014 Superb Elegance 2.0 TDi CR 4x4 Elegance (170bhp) DSG.
Do they all do this?
Thanks in advance for replies and advice - do I need to take it back to dealer or is it a 'feature' of the car/engine?
The two sources of noise from the front that are well documented on here are the heat shield (If it's a metallic rattle) and the air box. Search for these and you'll hopefully have your answer.
also (and this is what I had) you can check the brake fluid -> clutch pipe. it runs under the battery, so you have to take out the airbox to get at it, but there is a metal section of it that can rattle against the bottom of the battery tray.
t.
