Amp. cable routing...
Where to route the power cable from the engine room to the "cockpit" Simple, difficult? Can I do it myself?
I always have a very decent ICE and can advise that you give my mates at Sextons a ring, they have done quite a few octavias and will be doing my vRS when I get it. :shock:
Pain in the neck more like i needed to run 50AMP cable to run radio gear, ended up drilling a hole on the passenger side footwell,
When you drilled the hole, how did you seal it? Is it only one wall of sheet metal? Did you drill it from inside?For 50Amp, do you need 30mm2 cable?
I used 50amp automotive cable from maplin, as its only a short length the volts drop is very low (apx 0.3V @ 35amp load) its about 7mm per core diamater, hole was drilled from passenger footwell side using bolts as a guide to where it came out, be very carefull there are brake pipes on the other side very close by, sealed hole with silicoln sealant.
Is it the 50A cable which elevates this post from my Maintenance to my Performance?
Yeh its POWER RELATED!
more POWER MAN
Don't blame me I only replied.
If you open the bonnet and remove the box matrix that lies under the windscreen wiper on the passenger side.
There is already a hole which will allow 8/10 mm cable entry into the passenger footwell under the carpet.
Well thats the one i used when i ran my cable from the battery terminals
GOOD LUCK
cheers didnt find that one is it under the scuttle panel?
Is it the 50A cable which elevates this post from my Maintenance to my Performance?[/quote:10d3af5d47]
Strictly speaking it should be in maintenance. I'll move it later for the sake of tidyness, but for the moment it can stay here.
Jon
The other reason its staying here, no-one has told me how to move stuff :mrgreen:
Yes its under the scutle panel
remove panel and then remove element to allow access through passenger bulkhead
It does mean taking the carpet up on the passenger side and is a bit fiddly but far better than drilling new holes in the bulkhead
Jon you got nothing better to do with your time...nice though
Check this picture. The red arrow shows whats its look like a groumet to pass a wire to the from batery similar to the factory ones at the right.
Also could it be possible to take the power from the nuts thats show the yellow arrow????? and forget to pass a wire o the front batery????
http://cards.webshots.com/c44398599urvfyr
