VAG CAN PRO
Hi - I am likely to need some alterations doing via VAG CAN PRO. I have full VCDS but it does not access the menu that I need.
Is there anyone in the South West that can assist please?
Garnett
Yeah I would like some alterations done too but the cable is £250 to buy.  Is there anyone in the Hampshire area that could help me out?
Might be worth adding what it is you want changing as in some cases dealer tools like VAS and ODIS-e might help too.
At a wild guess, the Green Engineering Menu enabling on the MIB Columbus :)
No its only the rear dual fog light and rear day time running lights I need enabling.
Sent from my D6603 using Tapatalk
I was thinking of Garnett :)
Bit far far you 2 to come to me - shame, I was down your way over the summer
Just my luck.
Andy - you must be psychedelic!
I also think ODIS-e can do both the green menu and can definitely do dual fogs/rear DRL for the MK2 FL.
I'm a little bit closer for you radders567 but still quite a drive although I keep meaning to come over to Portsmouth so if I do I'll give you a shout.
  • 4 weeks later...
I have just bought a new VCP lead including P&P for £162.
Where did you buy it from
Poland - Still the same price.
Any chance of a link
