312mm brake fitting to 4x4 estate
Have just fitted my 312mm brakes & they certainly fill the wheels better ! :thumbup:
As i've reused my calipers & new pads I didn't have to do anything other than:
take wheel off,
- this was a real pain - first broke my 3/8 adaptor, then broke my 17mm 3/8 socket. Both were Halfords Professional so went to Halfords & got replacements. Also bought 1/2 17mm deep reach & short sockets so got back home & using a 5ft bar on the 17mm 1/2 deep reach socket managed to undo the wheel nuts. Did all 16 at the same time just to make sure.
Front 8 nuts were all +250Ib's - bloody air gunners. :thumbdwn:
remove the metal caliper clip (large flatblade screwdriver)
undo the 2 x 7mm caliper allen bolts,
stand the caliper on an axle stand (to not stress the hose),
remove the 2 x 18mm caliper mount bolts,
undo the disc grub screw (large crosshead)
remove disc
fit larger 312mm disc, & re-install the grub screw
fit larger caliper mount - lock-tight the 2 x 18mm bolts
refit the caliper - lock-tight the 2 x 7mm allen bolts
reinstall the metal caliper clip
put wheel back on & torque to 120nm.
Then remember to take pictures, then
repeat on the other side then test drive - gently.
Ist side took 35m.
2nd side 20m.
whole job took 5hrs due to not being able to undo the wheel nuts !!! :gnasher:
Pete
here is the pics
7137.attach
7138.attach
7139.attach
7140.attach
7141.attach
So it's dead easy on an Octy? All I need is the caliper carrier and the disks? No need to bleed the system either :cool:
Where do I buy the carriers?
got the calipers, discs & mounts on Ebay for £56. Search for Audi TT or 312
Pete
That's assuming you have 288mm discs as standard which the 1.8T's and 130PD's have. Lower spec models will have 280mm discs which are easily recognised by the mark 'FS III' stamped on the caliper. If you have the 280mm discs then it's an even bigger job than on the Furby vRS as new hubs are required.
If you can't find the carriers used I think they can be picked up new for around
I seem to remember Sarah(JBS) found out that vrs carriers from skoda were in fact £154 (ex VAT) new - so i went GolfTurbo route and got the TT setup(now fitted :D). If that helps
Lee
Damn - I assumed you needed ned calipers and pads for the 312 discs. I have only just changed my standard discs :(
Wheel bolts are 17mm is by the way.
And carrier bolts are 18mm.
Now ammended !!
That was yesterdays issues & still trying to warm up !! - LOL
Pete
  • 1 year later...
Just been told I need new front discs and pads to get my 4x4 through it's MOT and I fancy upgrading to the 312mm's - but can I find any 2nd-hand caliper carriers?? Anyone know anywhere that has any? (lol - too many "any"s) And what sort of price I should be paying? There are some on ebay from Spain at £110 including delivery - but compared to Diving Pete's £56 it seems a bit steep...
Thanks for any help anyone can offer.
I've got a set PM me with an offer
I'm about to do the same modifications. So you needed the 312mm RS discs, caliper carriers and those hexagonal bolts? I have got the discs already...and I'm wondering where can I get SH carries from? Thank you !:thumbup:
me ;)
Well then, but how? I'm not from UK or Ireland...
ah
auroan - yhm
goochie - so do u
I can do a good deal on a set that is as good as new!
I'd go for one on the sets from Golfturbo, nice new calipers, carriers, discs and pads. Could then e-bay the old calipers.
hmmmm, taking a sale away from me :( anyway my carriers came from golfturbo.
so out of interest how much is a full set golfturbo?
Don't worry, found your ebay listing.
Not intenionally buddy sorry.
Im sure your carriers would make a cheaper alternative, just pointing out all the options.
yeah, no worries ;)
Please don't berate me for a stupid question, but are the pads for a TT the same as the pads on my 4x4? I've bought auroan's carriers and nearly committed to buying a Mintex "Brake Box" for the Audi TT, before I stopped and thought "I know the discs will fit, but are the pads the same??"
If not, can anyone recommend a reasonable combination of discs and pads (hoping not to spend more than about a ton)?
