Bulb Change?
Is it easy to change the headlight bulbs on the Octavia III?
My old one was a synch by removing the headlight unit! Not  sure about the new one!
I haven't had to do mine yet (only 700 miles on the odo) but I think the main bulbs are done via a screw-cap on the back of the headlight unit. Indicators require a rear section of the headlight to be cut out then patched afterwards. Front fog lights are removed from outside the car using part of the tool kit.
Headlight bulbs easy to change under bonnet, a large cap unscrews behind each light unit.
