Electric window fell down and window motor horrible crunching noise.
Hi All,
Today of all days, in this weather.
Went into a car park, hit the wrong button to lower the window. Passenger one came down, with a loud noise. Stopped it and pressed up. This then made the glass fall down.
Now when I try the window there is a horrible crunching sound that is rather worrying.
Have managed to pull the glass up and it is intact, but an inch from the top and will not go any further.
I have pulled the bottom of the door card away and had a look, but I think the issue is behind the carrier?
I thought it was a broken motor but a little searching is leading me to think the regulator? Is this something I could change myself?
Also, how can I get the whole door card off? Is it just a bit more forceful pulling at the top or is there more hidden securing points I am not aware of?
Any ideas?
Thanks,
Scott
My carriers are bolted on, being a 2001 car.
So if I understand that correctly, it is a whole new carrier? The regulator is attached to that?
Any idea on a part number/cost?
Seems like something I may be able to do with my limited knowledge/tools depending...
I have most of the door card off, similar to the sealing threads. Is it just a case of levering/pulling the top off to take it off completely?
Thanks for your help! :)
You can buy just the mechanism if you want to fit it to your own door carrier but it's a bit fiddly. http://www.ebay.co.uk/itm/SKODA-FABIA-MK1-1999-2008-FRONT-LEFT-PASSENGER-SIDE-ELECTRIC-WINDOW-REGULATOR-/170981924857?hash=item27cf511ff9:g:XPwAAOSwo0JWMkrl
Or you can buy the whole carrier with mechanism already attached. Plenty on ebay http://www.ebay.co.uk/itm/BRAND-NEW-SKODA-FABIA-2000-2008-LEFT-FRONT-WINDOW-REGULATOR-6Y1837461-/201396680380?hash=item2ee42d76bc:g:TkUAAOSwyQtVuJhb
Edited by TMB
Or you can just buy new wires and pulley as a repair kit...
www.ebay.co.uk/itm/SKODA-FABIA-WINDOW-REGULATOR-REPAIR-CABLE-SET-FRONT-LEFT-PASSENGER-SIDE-/111456531499?fits=Model:Fabia&hash=item19f353b42b:g:dTgAAOSwv0tVYmEq
Get a regulator, they're about £30 off Euro or a specialist. It's not the worst job to do, but you need a bit of patience to back track if it's not right.
There's a metal card behind the door card, it all bolts to that more or less. Take the soaker of while you're working to give you a decent hand hole.
I got the complete regulator and panel from ECP for less than £50. Easy enough job.
Soaker?
Speaker... Sorry, typing badly on my phone.
^ Oh right :thumbup:
Appreciate all the help guys. Was something I wanted to tackle myself, but I decided that I needed the car complete sooner than I could do it myself.
Goes in to the garage near work tomorrow. This way it is done in a day and not the longer time it would take me. A lack of daylight when not working and then poor weather when I can get daylight, just isn't worth the hassle for me.
