Nilfisk Pressure Washer
Ey up. My rather costly Karcher has given up the will to live. I've taken it to bits and potentially it could need some very expensive bits to make it go again so I've got face on.
I bought it about 7 years ago after my cheap Aldi one blew it's insides onto the pavement. I thought you get what you pay for so spent £150 on a half price Karcher which has only had light use and hasn't been worth the investment.
So saw this at Screwfix. Cheap and cheerful. Is Nilfisk any good? Not really heard much about them tbh.
http://m.screwfix.com/p/nilfisk-alto-c110-4-5-pca-x-tra-110bar-pressure-washer-1-4kw-230v/61462
To add to Chris's post, their customer service is excellent also.
My gun had a fault after a year and they sent me a brand new one no questions asked.
Buy with confidence :)
Just to add...I had a cracked outer shell of the hose..They conceded that it was a design fault and replaced it free for a much longer rubber coated professional hose
Also, the washer in the trigger had worn and was leaking, I rang them and they sent me a new washer, free (Out of warranty)
As you can imagine, it gets a hell of  a lot of stick...I cant recommend enough
That's good to hear. I think my mind is made up then. Cheers chaps. Just one question. The little plastic bottle thing on the back. Is that a bog standard soap reservoir, or some type of snow foam attachment?
It is just a detergent gun, and nothing like as good as a lance, get a foam lance and definitely get a Nilfisk.
Edited by kentphil1
Perhaps a little late but for what it's worth I bought one of these a couple of weeks ago - same model and also to replace a Karcher that didn't last well for the limited use it got - one car once in a while and the patio about once a year. So far I'm impressed with it, at least as good as the Karcher and around two thirds the price. And it's very quiet. Good news to hear the after sales service seems good.
The only negative for me is filling the attachments I find isn't as easy as with the Karcher, but this might just be getting used to the different fittings.
And if I could ask a question of others with Nilfisk washers, when it stops do you get a short "squeal" each time? If this isn't usual then I'd better get on to Nilfisk.
Yes..Normal..dependent on the model ( I believe its a pressure release valve)
I find the attachments easy to get on and off...a slight smear with silicone grease or Vaseline will help
Yes, and it drives SWMBO mad! I'm not bothered, but then I know when it's going to happen...
Yep, Nilfisk > Karcher.
At my time of purchase, Nilfisk used metal, as opposed to Karcher's inferior plastic pumps, at a similar price point. Though I can't speak for current models
As for the squeal, check the condition of the connection O-rings. If they are perished and leaking, that can cause a frequent squeal, as the pump is constantly trying to maintain pressure.
Its just pressure relief on certain models
Yes it can also do it when there is a leak caused by perished o rings in the handle through prolonged use and time
My last Nilfisk was commandeered by my daughter so I'm now awaiting the delivery of another (better) one that will replace it. It might even get used before the impending monsoon later today!
I've had so many Karcher PW's die that I'm hoping the same doesn't happen to either of the Nilfisk's!
You wont be disappointed
Nilfisk will last year's. They have a metal motor. Better than the karchers. It was the only manufacturer I looked at when getting mine
Sent from my Galaxy S5
