How do I see if I have a MY16 or MY15
How do I tell from the VIN number whether I have a MY16 or 15
Does the VIN coding tell me.
What are the visible differences between the two.
My new Octy SE L  has just been delivered and my curiosity has been raised by the fact the Amundsen has 2 SD card slots
Also there is a rubber mobile phone holder near the handbrake
http://www.briskoda.net/forums/topic/354946-car-details-from-vin/ should be able to tell you.
If it's a new build car, rather than from stock, then it will definitely be MY16.
On MY16 only Columbus has a CD player.
The Amundsen went from 5.5" low resolution screen to 6.5" high(ish) resolution.
I think the SE L changed from a 4 spoke steering wheel to 3 spoke.
The 1.6 TDI changed from 105 PS to 110.
Edited by Rodge
Code G so MY16
Has a 3 spoke wheel
Is the Amundsen screen size measured diagonally like TV's or width. Its 6.5 ins diagonally or 5.8 ins width
How do I tell the resolution
It does not have tyre pressure monitoring
If it's SE-L it must be MY16.
If it's 15 it would be Elegance
all cars by law must have tyre pressure monitoring now!
My mistake, it does have TPMS. works differently to my daughters new Corsa which has miniature transmitters in each tyre valve
Yep indirect TPMS working off the ABS sensor data.
Blimey, didn't know that..
Simple way to tell is if you haven't upgraded to Columbus head unit, you won't have a CD player in the glovebox box if you have MY16... The CD tray is blanked out.
Sent from Tapatalk for Android
Yes no CD player but has two SD card slots, one for nav data and one for music
As far as I know there's always been 2 SD card slots. One for Nav SD card and one spare for music etc
  • 2 years later...
I don't have a CD player but only one SD card slot for music so will my Octavia 16 plate reg May 25th be a MY15 or MY 16
10th Character of the chassis number is the model year eg A = 2010 B = 2011 and so on.....if that helps. Model years usually run from May to April just to confuse things even more....
it does thank you x
Hi Octyal,
Many thanks for that informative posting regarding the chassis number assist toward establishing the model year.
I hope to acquire a 2017 (March registered) Octavia Scout 184 DSG in the very near future. Should I expect the 10th character of the chassis number to show 'H'?
And are there any other matters of note, as I migrate from a 2010 MK2 Scout Tsi?
