Alternatives to Speedo
I've an old van whos speedo has stopped working.  Again.  I'm not going to replace the instrument cluster and bits of the wiring.  Again.
I've been using a sat nav to tell how fast I'm going - I'm hoping there is something out there that's less than £20 or so and will tell me my speed.
Anyone have any ideas?
Should also add that I'd prefer not to use apps... my current tariff is data expensive.
Edited by jme808
A bicycle speedo?
Shorts; speedos should be banned.
From 2012 no working speedometer is an MOT failure.
Speedometer
The car will fail if a speedometer is not fitted, is incomplete, inoperative, has a dial glass broken/missing or cannot be illuminated.
Plenty of kit cars have passed the SVA with bicycle style electronic speedos
GPS is independent of data network. Torque or Torque Pro on a smart phone will show GPS speed even if run stand alone without any feeds from OBD2. It would be better to invest in a modern GPS unit rather than rely on the tiny AGPS/GPS/aerial in the average smartphone however. Dunno if you'll do it for £20, even these days.
Even freebies like Navi show the speed based on GPS signals - assuming your phone has a GPS sensor. The speed readings will be a lot more accurate as well, unless you habitually drive in very built up city centres with lots of tall buildings (you can lose the signal).
Speedometer
It's not a car though - the test criteria is different for commercial vehicles.  It's gone through the last 3 MOTs with no working speedo.
I might have a look into that - I thought the higher speed might confuse things... Thanks.  I didn't know that about GPS either - always assumed it was data.  I've learned 2 things today... I'll have a day off tomorrow.
The service history is great though - it's only done 1000 miles in the last 4 years...
That explains my Daily Dice With Death Commute on the M8! ;)
GPS is not acceptable on the SVA test, so I doubt it will be on a Commercial MOT.
