Orange Instrument lights
Just what is the problem?
If you watch the video there are lights lighting up then going out, around the dials. Then the "SET" symbol lights up briefly.
Thats what I see
Edited by Auric Goldfinger
Do you have anything sat on your other seats?
Are the multi-coloured dials exclusive to the VRS, or does our L&K have a setting to bring them on?
I thought the colour around the dials was just a reflection of an outside light source ?
Thats what I see
To me, it just looks like reflections of outside lights. The whole area around the "SET"- button and the stearing column is litten up and going out.
Edited by citembe
I can't see anything wrong there at all. It's the orange street lights that are reflected on the dash. The "set" button does not illuminate.
It's not a reflection of any kind. The back lights change from the normal white to orange in this strange sweeping patern. I will take it to skoda after the holidays. It never use to do it just started after a year or so and it's getting more frequent. More apparent when cold. Seems not a very common fault then. .. Lucky me.
Edited by Steveh3
:D :D Is this a wind up??  It's clearly the reflections of the street lights.
The orange light is all over the display. Streetlights reflection.
There is no fault, it's outside light reflections like many have already said. You can tell this because parts of the cluster that do not have any lights behind them, e.g the black background, are lighting up too. That and the pattern looks exactly the same as reflections from streetlights as you drive past them.
One question, have you just started leaving the blind open on your sunroof?
Like I said it's not an external reflection of any kind. It's as stated no mistake.
Drug is bad !
Are you taking the mickey???
It is a reflection. Look at the black background and the orange reflections passing over it. It cannot possibly light up on it's own as it's just black piece of plastic. And the O.O/SET button does not have a light behind it either.
