Latest Infotainment version Bolero
Yes, if you are interested pls contact me on PM
  • Replies 998
  • Views 232.5k
  • Version 0490 is now available for Briskoda members. If you are interested please PM your gmail address (instead of posting your request here). Please don't upload it to file sharing sites but feel
  • Have a look in the other thread I posted in. You can update your firmware but you will need to pm aki78 for instructions. I noticed quite a bit of speed increase with 465 / 475. The update process isn
  • Guys, check your PMs.
Hy Guys
i would like to have the latest Firmware Version to my Bolero .
It‘s possible to get the Download link ?image.thumb.jpeg.33f3996eaafb91b4810660865b4de37c.jpeg
11 hours ago, AtanasYordanov said:
Hy Guys
Yes you can have a PM for 0253
@varooom
i got info from Skoda Austria with my bluetooth problem after firmware update.
you left the conversation we had 😞
1 minute ago, mrlittle said:
@varooom
I need space in my inbox, it gets full.
Feel free to remind me of our conversation back there in PM land.
Awaiting your PM update ☺️
I have a problem. I can't get to the green (engineering) menu. And when updating to MST2_EU_SK_ZR_P0253T, it gives me an error. Do you have any ideas?
@AtanasYordanov
Green Engineering Menu needs to be enabled in VCDS, if that what you want.
Meanwhile, engineering menu should be available, and in theory be able to update firmware, but it could be the internal storage in the Amundsen radio is corrupted.
I'll try a factory reset, then I'll try the engineering menu. I will write about the result.
Best of luck with that task
Good Afternoon
Would it be possible to get a firmware update for the system below?
Steve
15 minutes ago, Babboon21 said:
Good Afternoon
Steve
Yes, I will send you link via PM
I managed to update, I used SD Card, with USB it failed.
But green menu does not activate, probably my cable is defective or weak.
/cdn-cgi/mirage/ca74ccc0c958c90dcfb1f2893c53ba68e43e63c06f0ba81c9f9acb2c1959ac8e/1280/https://www.briskoda.net/forums/uploads/monthly_2023_01/image.thumb.jpeg.7164f6a120bfd999bedc8a1311688318.jpeg
Glad you was able to update firmware.
What did you need the GEM for?
Also did you login to controller first for security?
No matter, I just wanted to view extra settings.
"Also did you login to controller first for security?" - No, maybe I had to enter some code into Security Access?
Yes you would need to login with security access, enter S12345.
Then try to change value.
Thanks, I have a green menu now.
Hello, can you please help me with the latest version of the infotainment system?
I will send you over a PM with link/instructions
Hey! Just bought a 2016 Skoda Octavia and looking for an update to the infotainment system if possible!
https://imgur.com/hJwYIut
Hello together,
is it possible to get a newer firmware version for my Bolero MIB2:
partnumber of device: 5Q0035840A
HW: H24
SW: 0252
It's a german device. German language is used.
It would be nice to get some download links and instructions. (The update from 0245 to 252 was already done by my self)
Many thanks to you!
1 hour ago, faXXen said:
Hello together,
HW: H24
SW: 0252
Many thanks to you!
You can get a small bump to 0253 via PM
Thanks! Update done, device is still working ;)
Perfect 🤝
Hello,
Any chance to update this one?
5E0035819A
Hw 041
Soft 0421
Kodek media: n/a
Very often sth gets screwed and the radio looses stations and radio icons.
Br
Robert
25 minutes ago, FishRman said:
Hello,
5E0035819A
Hw 041
Soft 0421
Kodek media: n/a
Br
Robert
I will send you update to 0490 version.
