Latest Infotainment version Bolero
Hey @pab567
Can you send me the latest software version for Bolero?
Device part: 5E0035840A
Hardware: 041
Software: 0435
Major thanks, man.
  • Replies 998
  • Views 232.5k
  • Version 0490 is now available for Briskoda members. If you are interested please PM your gmail address (instead of posting your request here). Please don't upload it to file sharing sites but feel
  • Have a look in the other thread I posted in. You can update your firmware but you will need to pm aki78 for instructions. I noticed quite a bit of speed increase with 465 / 475. The update process isn
  • Guys, check your PMs.
PM
PM
Hi @pab567,
Is there update available?
Dzięki 👍
PM
Hello @pab567,
Is it possible for you to send me an updatefile for my Bolero?
Much appreciated.
5 minutes ago, antti3 said:
Hello @pab567,
Much appreciated.
You have PM for MSTD_EU_SK_P6230_0490 file
@pab567
Hey,
Device part: 5Q0035840C
Hardware: H41
Software: 0468
Much appreciated.
PM
Edited by pab567
Hi there,
I have just bought a Karoq 2019 and think the infotainment may need updating (see below). It does not have a Wi-Fi option in the menu meaning I cannot smartlink by hotspot from phone.
Thanks for any help
6 minutes ago, bad_chili said:
Hi there,
Thanks for any help
2 Things, hold down your Menu button for a few seconds to enter the hidden menu, you are looking for Software Train this tells you exactly the correct firmware for it.
Next major thing to add, is the firmware updates rarely add features if at all.
Hi there,
Thanks for the reply, have added the pic below. I read in another post that there was an issue with certain models having this feature (WiFi) turned off from the factory and perhaps a code needed adding? In any case I thought I would check the firmware/software was up to date as a start point.
Thanks againPXL_20220726_090747951.thumb.jpg.d8aa36d771bcb3c75ebe36c6f0e1954c.jpg
I shall PM you 0480 in a few minutes, probably won't fix what you wish, but at least your unit might respond better
Hi, can you please send me the new version of Bolero SW for the following type:
Hardware: 041
Software: 0468
Many thanks
@Mmarm For safety, please supply your Software Train version.
You can find this from entering the special menu, press and hold Menu button to find.
Hi, this is the current version!
Thank you
Thank you
0480 is the current version of this Software Train
Is the software update the same for Octavia and Scala? I have H040 and would really appriciate if someone can send me the update :)
Look at the picture above, quotes Software Train, it also has the firmware update button (needed)
Hold Menu key down and provide details.
Thank you!
11 minutes ago, FilipT said:
Thank you!
Potentially you are looking at MU SW 1760
I need to unpack and check the supported SW Train seen in image is on the "list"
Is that normal, is safe to update?
Yes you should normally find that there are some updates for modules and not for all.
Depends on previous version on system as to where the updates need to be.
Sucess! Thank you !
After update I'm getting this notification, is there way to turn it off?PXL_20220805_083939454.thumb.jpg.f4472b4169d66373476be678ec2c40b6.jpg
Hi there, owner of a 2017 Octavia VRS here. Was looking for the newest update if anyone could help me. Thanks so much.
