TRP Spyre Brakes.
These are the 2nd generation and not subject to the original recall.
A mechanical disc brake that offers superior performance and is a snap to set up.
The Spyre is a dual sided mechanical where both pads actuate providing even and precise clamping force. This translates into even pad wear and, with the addition of a simple cable barrel adjuster.
Comes with used 160mm rotor and includes all mounting hardware and adapters.
FEATURES:
* Dual sided actuation.
* Works with ALL cable actuated road levers.
* Superstar kevlar pads fitted & comes with a new pair of Superstar Organic pads (Any pads in Shimano's M525/M515 fitting will work)
I have used them for just over 1 year & have now changed to hydraulic brakes. As you will see from the pictures they are in very good condition & work flawlessly.
The rotors are both 160mm, they show signs of use, they are slightly discoloured but still work perfectly well. The mounting adaptors & bolts are all new and unused.
£75 posted (recorded delivery)
£70 collected (S36, Penistone Area)
Matthew
SOLD
Guest
