Changing springs and dampers next weekend
Don't have one, and alright cheers tech, any special tools I'll need other than the usual
Rachet and sockets
Tourqes socket set
Breaker bar
Spanners 10 13 15 17 19 ( can't see it being other)
Jack
Axle stands
Anything else?
Also reassembly, any oil or grease to apply anywhere?
Pinch bolt is a spline head. Not sure on size. Ball joint splitter, spring compressors.
  • Replies 61
  • Views 4.3k
  • I'm doing it with two of my mates who have more experience than me and have done a lot to their cars, I just don't want to stand back and let them do it. I'm taking everything people are saying into a
  • If you haven't got a air gun or a proper battery powered gun I would suggest popping to a local garage and getting them to loosen the strut top nut before you remove the struts.
  • Tbf this is the correct answer
Maybe a read through a Haynes manual might help you.
Or take it to someone that knows what they are doing.........
:clap:
OP please please use a torque wrench and torque it, if you'd have ever driven a customers car when lower bolts come lose from them just nipping the bolts up you'll know
:clap:
Needs to be remembered here that the suspension is one of the vital parts that's keeping your car on the road,so as above please ensure its done properly! :)
In my opinion if you have to ask what to do on these components, let someone who knows what they're doing do the job or at least get them to watch over you as you do it. Torque all bolts etc, check balljoints for wear as lowering can tend to increase wear rates, most importantly remember your suspension and brakes are only ever as good as the tyres you have fitted.
The damper slots into the hub and has a single pinch bolt.
Cheers, that's what I meant, so I agree the spreader, and the Stilson is not required after all.
When I get my hands dirty and take the wheel off ill be able I see what I have to do.
In asking just to be better prepared, is that not what briskoda is for?
Look at it like this. You say you want to prep but then you say once you're looking at it you'll know what to do and you're going to do it without a Haynes manual or ERWIN download. Those are contradictory positions.
I think people are concerned you're getting yourself into a situation that you possibly don't need to, or that you may create problems for yourself that will make the job harder and more expensive than it needs to be.
I don't know the background of half the posters in this thread, but Tech1e was/is Master Tech qualified on VW, Skoda and SEAT. He was effectively the first person to do most of the mods we now think of as standard including Eibach/FSD suspension upgrades, 312mm brakes etc. and he was one of the people who set up Unit 18 and he built the original vRS estate among many other pretty special things so when people of that calibre make helpful suggestions, they're probably worth listening to.
Getting a gentle ribbing about tears is a sign of how friendly Briskoda is. On Pistonheads or the TT Forums they'd have ripped you to shreds instead of trying to be helpful.
I'm taking everything people are saying into account. I have a torque wrench which I will now be taking along with the figures which I'll find out. I'll go pick up that took tech1 suggested being as its under £10 so I may as well make it easier as he says.
E/ I've already bought new top mounts to replace at the same time as someone suggested as well
So far listening to briskoda has saved me slot of time and money. Last week I fixed the wire on the starter motor solenoid which had snapped, for free and only took about 40 minutes! I also did the brake light switch sensor on my old 1.4tdi using a step by step guide on here, otherwise a grave wanted nearly £200 apparently, it only took my an hour or so and the part cost a few pounds! Friday I fixed the leak in my door with help from here and a YouTube video, again for free.
I do listen to people on here, most of which have more knowledge and experience than myself.
Edited by AdamOP94
  • Sponsor
This site might be useful: www.workshop-manuals.com
Every couple of screens you have to kill a 'donate?' pop-up, but the info is generally handy for torque settings etc.
Here's the start page for front strut, keep clicking next down in the bottom right hand corner to scroll through.
There's a similar set of pages for the rear set up, starting here .
I looked up some torque settings for you Adam.
Front Suspension
12-point driveshaft nut (use new nut).
Stage1:  50Nm
Stage2: Tighten further 45 degrees
Balljoint to lower arm bolts:
Stage1: 20Nm
Stage2: Tighten further 90 degrees
Strut pinch bolt:
Stage1: 60Nm
Stage2: Further tighten 90 degrees
Strut piston rod nut:
60 Nm
Strut top mount to body:
Stage1: 15Nm
Rear Suspension
Damper lower mounting nut and bolt:
Stage1: 40Nm
Damper upper mounting to body:
Stage1: 30Nm
Damper rod top nut to bracket:
25Nm
Front Suspension
Stage1: 50Nm
Stage1: 20Nm
Strut pinch bolt:
Stage1: 60Nm
60 Nm
Stage1: 15Nm
Rear Suspension
Stage1: 40Nm
Stage1: 30Nm
25Nm
Real helpful of you man I appreciate that.
^ You're welcome :)
great guide here. Not that you need to do it like this but it is a good walkthrough
http://www.seat-ibiza-mk4.co.uk/ibiza_front_shock_absorber_change.ht
I think the fabia should be the same right?
if you get a spark plug socket piece (forgotten what size) that can fit a spanner around the strut top nut then you can get an allen key with vice grips or allen bit through the centre to get the top nut off the strut. otherwise the piston will just spin
like already mentioned an impact wrench is the other option.
hub may need a fair amount of hammering to get off even once it's spread. keep hitting it around all sides as long as your not killing it or any gubbins!
If i was doing it again i'd get better spring compressors. the dual hook cheapo ebay ones i used were a pain in the ass for access and required some modification to not scratch the paint off my new springs
rears are super easy :)
Edited by corndog
Cheers mate, and I do have those cheap 2 claw ones haha, 3 of then in fact.
Did I miss something or are you on about the other method, I thought i was alright to take it off as a strut with the Spring on, and the new springs and dampers are already assembled as well
Ok, I'm now not sure you need compressors at all, or indeed new top balls. However, if you do need to use the compressors, use all 3 at 120degree spacing, and do them up and down half a turn at a time.
No your strut will need building up,you need to remove your top mount and fit to the new set up.
So you will need to compress your standard springs to remove the top mount,and if your lowered springs are 'progressive' you will need to compress them to get the top mount on.
They are assembled? Have you bought second hand?
Maybe they're not I haven't got them yet.
Brand new, my mate said they will probably come Assembled I guess not.
I very much doubt they will be assembled.
They are not likely to ship a spring and damper unit that is compressed for safety reasons.
Edited by Tech1e
Isnt "my mate said..." usually about the same as "...never happens"? ;)
If this is your m8 that's meant to be helping you and 'knows' what he's doing I would doubt his ability to do the job if I was you! :)
Hahaha fair point guys but he has done a lot to his car, when he modded his first car he literally did everything himself, including all interior and bodywork, refurbed the wheels etc not just throwing on come lowering springs.
Tbf in this weather I really am not feeling it, anyone know what kind of price it would cost to get it done at a garage?
If it goes to plan it's not much of a job for a garage,I would say £60-80 cash job
