Adding second Reversing Light?
My drive is rather dark and the wife's pot plants are a definite parking hazard, is it possible to make the other reversing light function? I do not have access to VCDS so it would need to be a DIY manual jobby. Used to be so easy, splice in a spur lead and attach the bulb and holder, simples.
Not sure how easy it would be but I couldn't imagine a second bulb would throw enough light out to do the job. Could you get a security light with a PIR over the drive? Or move the pot plants.
My Vrs ( 63 Plate ) has 2 reversing lights
I'm 99% sure SWMBO's 63 plate vRS estate has 2 reversing lights.....
Just been out to double check
I have 2 reversing lights, one each side
As others, 2 revers lights here too.
Rear light so poor didn't even check :doh:. We do have a PIR light but misses the pot plant area. Those LED lights look interesting (Thanks aki78), have to check on them as well. Hope Powerbulbs do them but haven't checked yet-next job.
Edited by ajw1100
Oh Well, PowerBulbs do supply Osram LED P21w ba15s LED's but both are noted as not legal for road/exterior use and needing CANBus warning canceller for LED's. Oh Well....
@aki78 are they non Canbus bulbs & did they need coding via VCDS
The LED reverse lights look spot on ;)
They worked without coding (and without bulb out errors), so "canbus compatible" in Octy3 as reversing lights. :)
A few weeks later I changed the coding to LED but only because my retrofitted camera is powered from the left revesing light and it needed pure DC.
Edited by aki78
  • 1 year later...
Hi, i have the same problem with my camera. Can you post which channel in adaptation must be changed to led?
Thanks in advance
Left: Leuchte28RFL LC11-Lasttyp 28
Right: Leuchte29RFL RA64-Lasttyp 29
Change them to '43 - allgemeine LED'
  • 5 months later...
Where is it possible to change these values in VCDS?
Which bit isn't clear? All the information for the adaptation changes is listed in the post you quoted? :blink:
sorry for being a bit confused, but i was wondering where you can do it, so if i have right is it from the adaptation section?
  • 2 years later...
I think you program with VCDS like this. But im not 100% sure :) Can someone comfirm this?
09-Cent. Elect. / Security Access – 16 (code: 31347) / Adaptation – 10
You search for:
Leuchte28RFL LC11   and change to   43-allgemeine LED
Leuchte29RFL RA64   and change to   43-allgemeine LED
I think you have to change dimmwert from 100 to 127 for both reverse lights to, but i dont know on what setting.
