Faults in my vcds scan
I've done a scan today and it came up with a few faults, so I cleared them and scanned again but they are still there.
In the past I fitted a reverse camera, which is working fine, and swapped my "A" Bluetooth module for a "D" version, which also works fine, so I'm guessing I need to code this new module. How do I do that? Are all the faults connected?
I've pasted the log below
Friday,19,February,2016,14:44:40:07794
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: TMBk************ License Plate: *******
Mileage: 120730km-75018mi Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62
72 77
VIN: TMBK******** Mileage: 120730km-75018miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CJ HW: 03L 906 018 BR
Component: R4 2,0L EDC H22 7828
Revision: 42H22--- Serial number:
Coding: 001D0012042500080000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01103L906018CJ 003006
ROD: EV_ECM20TDI01103L906018CJ.rod
VCID: 74E7906DDFA55D9E6A-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 H HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2208
Revision: 05151112 Serial number: 00001008251405
Coding: 0000020
Shop #: WSC 33361 790 00055
VCID: 193981D9D087C0F699-804C
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 863D6016092400FD610B06E9901C0082350800
VCID: 76E3AA65C1D94F8E54-8022
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 0305C3B18A0B6A2663-8056
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 P HW: 1K0 937 087 P
Component: BCM PQ35 H+ 104 0615
Revision: 00104 AE
Coding: 48010AB8E85BF1C040080080110089E4427000AE736D85605C0140000040
VCID: 3E737245A969C7CE4C-806A
Subsystem 1 - Part No: 3T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 20081 26 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 040910 05 54 0403
Coding: 0730ED
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 120618 km
Time Indication: 0
Date: 2016.02.13
Time: 14:08:40
Freeze Frame:
Term 15 On
Voltage: 11.45 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 3T0 919 475 A HW: 3T0 919 475
Component: PARKHILFE PLA H07 0003
Revision: -------- Serial number: 78331020003089
Coding: 301108
VCID: 3B757B51BA7BD2E66B-806E
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 3T0 959 655 B HW: 3T0 959 655 B
Component: J234__LDB VW10 HI 1916
Revision: 19014000 Serial number: 003GRPJ6962R
Coding: 0017474
VCID: 408F0CBD139DB13E3E-8014
Subsystem 1 - Serial number: 6332MTS659572360
Subsystem 2 - Serial number: 6342MTS609452360
Subsystem 3 - Serial number: 6351HTS6NVMEE9KR
Subsystem 4 - Serial number: 6361HTS65ATEE9KR
Subsystem 5 - Serial number: 63727TS6RVA3E9KR
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100823200842
Coding: 188A140000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF3B245E1E907CE0C-802A
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 3T2 920 941 H HW: 3T2 920 941 H
Component: KOMBI H04 0406
Coding: 711F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 3A7B7E55BD41EBEE70-806E
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 040910F2001461
Coding: EDA1FF0640060200009303
VCID: 6DD18509748F8C56A5-8038
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 116897 km
Time Indication: 0
Date: 2015.08.20
Time: 14:45:30
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0406
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADB8E158D619B6EC0-803E
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000003
VCID: 72EB96756DB153AE78-8026
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680 A
Component: RNS-MID H42 4120
Revision: AB001001 Serial number: SKZ6Z7K6252059
Coding: 04000442000400810000
VCID: 2F6D5F017E033E46D7-807A
Subsystem 1 - Part No: 3T0 051 859 AL
Component: EU West V13 8348
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 116897 km
Time Indication: 0
Date: 2015.08.20
Time: 14:45:29
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 C HW: 8X0 959 793 C
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011D0220DE01001000
VCID: 4D91258914CF6C56C5-8018
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 196 3001
Revision: 00H17000
VCID: 31695979A83728B6C1-8064
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 C HW: 8X0 959 792 C
Component: TSG BF H09 0409
VCID: 4C97288DEFD5655ED2-8018
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1377095
VCID: 3467506D57251D9EAA-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000021
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000021
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 116897 km
Time Indication: 0
Date: 2015.08.20
Time: 14:45:29
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 B HW: 8X0 959 795 B
Component: TSG HL H06 0409
Coding: 010C00200001001000
VCID: 4E93228519C9574EBC-801A
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H06 0409
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0946
Revision: -------- Serial number: 35502105012785
Coding: 020000000100000000000101
ASAM Dataset: EV_UHVPremi 002708
ROD: EV_UHVPremi_SE36.rod
VCID: 2447A02D2FC58D1E3A-8070
2 Faults Found:
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Open or Short to Ground
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 240
Mileage: 116851 km
Date: 2015.08.17
Time: 16:05:06
13636352 - Control module not coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 240
Mileage: 116851 km
Date: 2015.08.17
Time: 16:05:06
End-------------------------(Elapsed Time: 03:33)--------------------------
Edited by ashfan
Appears to be a coding issue with the BT, long code looks a bit sparse. You might have mic diagnostics active or the three button key pad active ticked to have that first fault.
Then on the other it sounds like the back up camera is ticked in the gateway but something with the radio coding isn't consistent. There are low line and high line cameras and you might have chosen the wrong one in the radio coding? That's where I'd be looking first.
Edited by adamal
Thanks Adam. I'll have a look today. I know about the cameras but being a complete novice with vcds and initially struggling to get the camera working I'm a bit wary of going in a bit blind.
With regard to the Bluetooth module is it simply a case of finding someone with the same module and copying the code.
Are mic settings and 3 button keypad in settings? I've never heard of a 3 button keypad so I doubt I'd have played around with that but I'll check it out.
Edited by ashfan
Check the bulb and replace if needed.
Which camera did you install? If it's not a high line version you should open the installation list in the gateway, look for 6C and untick it.
I would check byte 6 and change it from 00 to 01 (3-button active to inactive) - assuming my memory is correct ;)
When you make the change to byte 6 above, fill in the importer number, workshop code etc. Any non zero values should do.
When you're done, clear all the DTC's and see which come back!
Many thanks for that.
I check the bulb every time I use the car,even looking for a reflection in the car in front when stopped in traffic and it seems ok. But I do have a spare so il swap it just in case.
It's not a highline camera so I'll have a look at that.
I'll see if I can find byte 6,like I said I'm a novice at vcds .
With regard to importer number and workshop code, so I can just invent a number without zeros.
They can have zero's in them but not be zero :)
It makes very little difference as long as  it's not 00000/000/00000. VCDS will offer to set it to their default which is 12345/123/12345.
In cases where a replacement has been made, I tend to use the values from the old unit to make comparisons easier.
If you access module 77 and then the coding it will take you to a screen where you can change the coding via the long code helper. This is where you find the bytes etc and I thought it was byte 6 too. It's pretty self explanatory and the three button keypad is a vw roof control pad so won't be relevant to your car.
It's better to use the long coding helper than manually amending the coding and copying someone else's, where the car may have different functions, won't necessarily solve things. Having said that the BT module is more likely than most to be consistent across cars.
Edited by adamal
I had a play today and found byte 6c in the gateway but it was already unticked.
I found byte 6 and on the same page there was a tick box option that mentioned a 3 button keypad which when ticked changed byte 6 to 01. Going back to the previous page I tried to alter the importer number and workshop code but it wouldn't allow any change at all even the vcds default value.
I took some screenshots but it was a pain trying to upload them using my tablet. I'll try tomorrow on my PC.
Thanks Adam. I don't know if I was doing things the way you've suggested but I'll try again tomorrow.
As you can probably gather I don't really understand how to use vcds and when I do use it I need word for word instructions otherwise I'm just guessing.
I finally manged to get round to having another attempt at this and I was accessing module 77 as you suggested Adam and trying to change things as Langers had previously suggested. I still can`t change the importer number and workshop code. I`ve loaded up some screenshots to show whats happening.
I go to module 77 and long code helper and get this
I put a tick in the box "Operating unit for cell phone operation" which changes byte 6 to 01
Choose exit and it takes me back to this screen
Click Do It. I then get this
And no matter which option I choose I then get this
I`m obviously doing something wrong but I just can`t work out what.
Looking at this screen shot it's not trying to apply new coding:
On the previous screen, rather than clicking exit, try hitting the X in the top right. Hopefully that'll fill out the 'New coding' section for you :)
langers you`re a genius. I never thought it was going to be that simple.
Just the back up camera fault to sort out.
Thanks to both you and Adam for helping me to get this far
Excellent!
The RNS510 looks correctly coded and the camera issues are all from about 4000km ago which might have been when it was fitted.
Probably worth clearing all DTC's and posting a new autoscan to see if the backup camera errors return.
Thanks for that. I`ve cleared the DTC`s a few times in the past and re-scanned but the camera fault keeps reappearing, yes it`s probably about 4000km ago that I fitted it. The new scan today is the same as the one above but without the bluetooth errors. I haven`t got round to trying a new bulb in the DRL.
The RNS510 is the original factory fitted as far as I know. I was tempted by a recent DAB unit in the Classified section but I don`t have the code for it to sell on
Thursday,25,February,2016,13:04:36:07794
www.Ross-Tech.com
VIN: TMBK**********  License Plate: *******
Mileage: 120780km-75049mi   Repair Order:
          72 77
VIN: TMBK*********   Mileage: 120780km-75049miles
77-Telephone -- Status: OK 0000
   Coding: 0000020
   Revision: 00H31001
   Revision: 00005001
   Coding: 0000000002
   Revision: 00104 AE
   Coding: 00D7B7
   Coding: 0730ED
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 150
                    Mileage: 120618 km
                    Time Indication: 0
                    Date: 2016.02.13
                    Time: 14:08:40
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 301108
   Coding: 0017474
   Coding: 188A140000
   Coding: 820000
   Coding: 711F01
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 116897 km
                    Time Indication: 0
                    Date: 2015.08.20
                    Time: 14:45:30
   Coding: 000000
   Coding: 0000003
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 116897 km
                    Time Indication: 0
                    Date: 2015.08.20
                    Time: 14:45:29
   Revision: 00H17000
   Coding: 1377095
   Coding: 00000021
   Coding: 00000021
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 116897 km
                    Time Indication: 0
                    Date: 2015.08.20
                    Time: 14:45:29
   Coding: 020000000100010000000101
   Shop #: WSC 12345 123 12345
End-------------------------(Elapsed Time: 03:25)--------------------------
As langers2k mentioned this feels like a high line camera with separate module is expected. Are you sure 6c isn't ticked in the gateway list?
Almost certain Adam but I'll check again today
I`ve had another look at 6C and its definitely unticked.
I cleared the DTC`s and rescanned and the faults still show. I don`t suppose its a big issue as everything is working as it should, even the LED DRL. I haven`t got round to changing the bulb yet
Edited by ashfan
Is there anything in the long coding helper for 56 navigation that relates to the camera?
Edited by adamal
Not sure if you mean 37 Navigation (couldn`t find 57) but if so I couldn`t see anything
In 56 Radio though there was a tick box in long coding for "Backup Camera Low (without control module) installed" and this was ticked
Also in the same 56 Radio there was for Byte 7, Bit 4-5 a drop down box which was showing "00-Display Variant:Highline". There were two other options, one was Premium (instead of Highline) but  I can`t remember the other option, could have been Standard. I`ll have to check again, but I`m not sure if this relevant.
Once again I`m having trouble uploading screenshots on my Acer Aspire One nettop that I use for VCDS.
37 and 56 are the same thing. That all sounds correct. Will take another look if you can load the pics.
Ah right. I've just spotted my deliberate mistake. Thanks for taking the time with this, I'll have another look tomorrow. If nothing else I'm finding my way around vcds a bit more.
  • 2 months later...
Apologies for not coming back to this but we had a bit of a crisis at home and then decided to go on a holiday.
I finally got round to changing the LED light bulb which was causing a problem in my first scan. I then cleared all faults and rescanned and as far as I can see the RVC faults and bulb fault has been cleared some how but another fault has been discovered.
The scan log is below.
Does anybody know what "Intervention Load Management" is?
**EDIT**  Just had a quick look at the Ross-Tech wiki and it seems it is simply informing me that the battery is a bit discharged and needs charging up. I thought the "Load" bit was something to do with having too much weight in the car doh.
http://wiki.ross-tech.com/wiki/index.php/00907
I don`t know why the RVC faults have suddenly disappeared, surely they weren`t linked to the faulty bulb.
Monday,02,May,2016,15:58:24:07794
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
www.Ross-Tech.com
VIN: TMBK******************   License Plate:
          72 77
VIN: TMBKF*******************   Mileage: 122320km-76006miles
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
Readiness: 0 0 0 0 1
   Coding: 0000020
   Revision: 00H31001
   Revision: 00005001
   Coding: 0000000002
   Revision: 00104 AE
   Coding: 00D7B7
   Coding: 0730ED
1 Fault Found:
00907 - Intervention load Management
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 169
                    Mileage: 122325 km
                    Time Indication: 0
                    Date: 2016.05.02
                    Time: 15:52:53
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 301108
   Coding: 0017474
   Coding: 188A140000
   Coding: 820000
   Coding: 711F01
   Coding: 711F01
   Coding: 000000
   Coding: 0000003
   Revision: 00H17000
   Coding: 1377095
   Coding: 00000021
   Coding: 00000021
Edited by ashfan
