Cigarette socket
Cheers for all the info it really is much appreciated.
 If you use the empty slot then keep the fuses to a low amperage, I used 2X 2.5a fuses.
Jonro2009, again having trouble sourcing car stuff in Oban, do the fuses need to be 2.5 amp or can they be a higher amperage, or what would be the maximum I could use for the dash cam. Cheers the noo.
Use the lowest value you can obtain until you can source the correct value. The fuse provides the weakest link and should be replaced with the correct rating as soon as you can really. I have a 2 amp fuse in my camera circuit.
+1 for this advice
Cheers guys for the info, much appreciated.
Thanks for all your help jonro2009, stared night shift at 7pm tonight and after a quick cuppa I had the camera installed and all working through the ignition in 40mins, now back inside for another cuppa as its bloody freezing in the garage, if anyone else out there looking to do the same it really is very easy if I can do it anyone can. Cheers for all the info to everyone else that helped it really is appreciated.
It's bloody freezing isn't it!
Glad everyone's advice has helped, it's a crackin forum! Peace of mind driving now and you will no doubt capture some beautiful scenery too!
Should work with the engine on too shouldnt it? If you're worried about getting a flat battery.
It works with the ignition when it's live, so also when the engine is on. Unless you have read something I haven't.
Edited by fabiamk2SE
I'm confused, are you on the right thread?
Ignore that then :D
Ive been dragged shoe shoppin n feelin mithered. Musta got confused :D
Haha, happy shopping!
Pleased you have got it sorted. The internal battery, if you have one, will be charged whilst driving. If you have a parking mode and you leave your camera installed, then it can record knocks that occur whilst parked up too. My battery only lasts for around 8 hours now though.
