Engine Whine noise
Hi All,
I've been having a world of fun recently with my 60k 2010 2.0 140 CR diesel!  in the last 2 months it has had:
  • new clutch and DMF
  • timing belt, water pump and aux belt
  • 2 new injectors
Since the recent work a high pitched whine has become apparent about 80% of the time, it sounds like alternator interference on a car radio used to.  It sounds as though its coming from the engine bay.
it doesn't do it when cold, but kicks in as the car starts to warm up.  I happens in or out of gear, clutch in or out, car moving or not moving, and although the pitch changes a little on revs, it isn't much affected by revs.
the fuel pump under the rear seat is running quietly.
although I don't think its connected I have a slight diesel leak form the fuel filter area which I am trying to track down, perhaps diesel is getting onto the aux belt and affecting it.
I suspect an pulley bearing / tensioner most...  Any wise words from anyone?
Water pump?
I would say the timing belts to tight and will get a little worse as the engine warms up.
Also be careful of the filter leaking with it being near the belts
Edited by Snapper1725
I had a similar whine which was the turbo. Luckily it was just under three years old and so replaced under warranty - a £1600 job!
So quick update to put this one to bed,
the fuel filter had been so damaged by an inept mechanic, that I think there was air getting drawn in between the lid and can making the whining noise.
sourced a replacement housing and had it properly fitted and no more noise.
BTW the housing is £208 from Skoda! but I found a brand new one from a German ebay seller called Mteile.  arrived in three days for £78.
