Fabia SDI vibrates annoyingly in low gears
hi there hoping someone can help me as im 20 minutes away from setting fire to my car.......
I have a 2001 fabia SDI, i bought it cheap off a guy with a few problems, i have fixed them all apart from 1....  As i am taking off in 1 st gear there is a horrible vibration through the whole car hich makes every piece of glass shake, it happens in 1st then into second then dissapears in 3rd, If i let the throttle off abit it dissapears. but increased revs slightly it returns.. Its not something I can live with and i really need some advice...
I have changed the gearbox oil, new tires, changed the nearside driveshaft (hoping ive changed it correctly)
please help me as I about at my witts end and that gallon of petrol is iminent...
Might get to put the matches away sooner if you ask in the mk1 furby section... ;)
  • Sponsor
Kindly moved here by a moderator.
Knackered dogbone mount? Other engine mount, gearbox mount?
Edited by Wino
forgive me for being slightly stupid as this is the first time ive used this site before, any chance you can point me in the right direction as to where I need to be, like a link to correct forum etc,,  :notme:
  • Sponsor
Don't worry. It's in the correct place now. It's been moved for you.
I have checked all the engine mounts and gearbox mounts and they seem fine but not checked the dog bone mount, any tips on how to proceed with this? i am a slight novice to the trade
alsp ive been doing alot of research and people have been talking about the dual mass flywheel, whats the chances of it being this, im hoping this is a worst case scenario. If it was the flywheel sure it would vibrate at low revs in high gear surely, its just a mystery as it only happens in 1st and 2nd? gearbox bearings maybe?
Mass flywheel?
Mass flywheel?
"Basically it's a flywheel in two concentric parts or two facing flywheels stuck together with flexible compound to damp down transmitted vibration from diesel engines, improve gearchange quality and protect transmissions from torque reaction at around 2,000rpm, particularly the change from first to second."
oh i do apologise, I read up the specs for my car and read that it had a DMF, got a clicking coming from the nearside driveshaft so whats the odds that will be my problem? i must have put the new one corrctly?
Might be the CV joint?
