MFSW and Maxidot
Hi all,
Just want to double check what I'd need to get this 4 spoke MFSW working in my FL VRS that does not have maxidot.  I assume I could use my existing airbag, but would need a loom to hook the buttons up.  Would it then need VCDS coding also?
http://www.cars-equipment.com/www/en/shop/four-spoke-steering-wheels-6/oem-3t0419091ab-4x-spoke-multifunction-steering/#prettyPhoto
Cheers!
Edited by planehazza
  • Replies 59
  • Views 11.7k
  • For maxidot, you want to look for part numbers starting with 1Z0 920 943, anything from a petrol should be fine and ideally SW:04xx or newer. If you do fit one, you'll also need the immobiliser reprog
  • Agreed Mike, the 5K0 953 549 B is definitely not right for the car in question.   Assuming rosstech are correct, the CH/CJ/CK modules all have a steering angle sensor built in where as the original
  • It looks correct for a non vrs petrol facelift, however that cluster only has km/H, not mph. Not sure that Skodateile sell an MPH cluster anymore.
Yes it will need VCDS coding to tell it there is a MFSW fitted. Be aware that as a non-maxidot car, it is probably fitted with a low or mid line steering column controller that doesn't support MFSW function. That will need coding with VCDS too.
You really need to get a VCDS scan of the car to find out exactly which version of SCC you have, and compare that to Ross Techs comparison chart on their website. as per here:
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Mike
Thanks all.  Sounds about right.  Maxidot is another retrofit I'd love but they're insanely hard to source, and very expensive too.  Is the steering column something that can be updated, or is that what you meant by VCDS coding? I have a VCDS log from when I had an error code, so I'm just looking through that for any reference to SCC etc.
EDIT. Here we go, typical, I have the low line :(  Is this a new (expensive) part jobby?
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
Shop #: WSC 73430 790 00000
VCID: 030E7F06426CC82640-8056
From this, you have a CQ version which is midline, and will need changing for MFSW. The module itself needs changing, then coding to your car, the coding involving resetting the steering sensor angle and other things.It's going to cost you a lot more than the price of the MFSW alone.
Mike
That's very true. I could get the high line module for £60 here:
http://www.ebay.co.uk/itm/VW-OEM-MFSW-MF-STEERING-WHEEL-MODULE-5K0-953-549-B-/261486140793
Surely I could source the wheel, module and loom for <£200 and factor in £20 to pay someone to VCDS code it all?
Assuming rosstech are correct, the CH/CJ/CK modules all have a steering angle sensor built in where as the original CQ doesn't. Therefore I'd be leaning towards a CD/CE/CF module (avoid the CF if it's an auto). It might be possible to use the CH/CJ/CK with the steering angle sensor coded out but I'm not sure.
Might be worth a pm to eddie-nl as he will definitely know :)
Ah I see. I'd misunderstood the ross-tech site - I hadn't realised that there were so many versions.
This one instead perhaps?
http://www.ebay.co.uk/itm/New-1K0953549CD-MFSW-Steering-Wheel-Control-Module-For-VW-Golf-GTI-MK6-Jetta-MK5-/151657607744
Whilst on the matter then, if I would like to go for maxidot one day, would it be prudent to get the correct SCC to support that also if needed?
I've sent Eddie a PM too :)
So whilst on the subject, is this the correct cluster for facelift mkii octavia petrol?
http://www.skodateile.cz/index.php?pg=product∏=280&menu=%C5%A0koda
Edited by ahenners
Yeah I just noticed that myself :/
For maxidot, you want to look for part numbers starting with 1Z0 920 943, anything from a petrol should be fine and ideally SW:04xx or newer. If you do fit one, you'll also need the immobiliser reprogramming and the milage correcting on a second hand clusters - Ed is your man for this but quite a distance from Newcastle ;)
From UK petrol models I think the full part numbers are as follows but you should check before committing to buy.
SW: 01xx
1Z0920943B non-vRS (Diesel version is 1Z0920943D)
1Z0920943C vRS (Diesel version is 1Z0920943D)
SW: 03xx
1Z0920943F non-vRS (Diesel version is 1Z0920943G)
1Z0920943H vRS (Diesel version is 1Z0920943J)
SW: 04xx
1Z0920943K non-vRS (Diesel version is 1Z0920943M)
1Z0920943L vRS (Diesel version is 1Z0920943N)
SW: 06xx
1Z0920943Q non-vRS) (Diesel version is 1Z0920943S)
1Z0920943R vRS (Diesel version is 1Z0920943T)
Just to add a little more information about SW versions.
01xx - Doesn't support premium bluetooth icons, so you end up with empty squares instead of icons when used be newer bluetooth modules, not updatable.
03xx - Is a version I know little about, not seen any reports it can be updated. May or may not support premium BT icons.
04xx - Can be updated to 06xx using the correct tools (it looses the needle configuration during the upgrade which needs restoring). I believe it should support premium BT icons.
06xx - Latest version is 0608 which supports PLA2.0, direct TPMS, refuel volume etc.
SW: 01xx
SW: 03xx
SW: 04xx
SW: 06xx
Thanks very much for this.  Trying to source one is impossible though ha
SW: 01xx
SW: 03xx
SW: 04xx
SW: 06xx
Great, informative post! Like PlaneHazza, I've been keeping my eye out for a maxidot cluster but they are like rocking horse s***!
Skodateile only have the preFL maxidot in stock.
I've just been lucky and managed to source one from a breaker out of a 2011 Octavia Greenline, it wasn't cheap but not as expensive if I had bought from Skodateile.
Do you have to sit and remove it from the car yourself or was it an online breaker?
It was online breaker, it hadnt been removed yet. I had to pay for it before they would remove it!
Hi guys, I'm back.  I really want a new stereo to upgrade the bolero and am considering a purely touch based android unit.  This is not safe without MFSW IMO as you need to be able to control volume etc without taking your eyes off the road - something you can't do without physical buttons.
Can I double check, that I'd need the following:
- Highline SCC 1K0953549CD  - http://www.ebay.co.uk/itm/New-1K0953549CD-MFSW-Steering-Wheel-Control-Module-For-VW-Golf-GTI-MK6-Jetta-MK5-/151657607744?hash=item234f7f7240:g:H6sAAOSwPhdVN1wp
- airbag loom
- MSFW wheel with/without new airbag
- VCDS coding
Is there anything else I'd need?
Yeap that's about it.
I've got a spare loom if your interested!
Yes please dude, how much would you be after?
I've got a MFSW going cheap too if you want to keep cost down.
Cheers, I'll be in touch.  Currently, I'm trying to work out what else I need, as several how tos are reporting that I may need a slip ring too.  Also, my current wheel is just the standard VRS 3 spoke wheel.  If going to 4 spoke MFSW, do I need a new airbag too?
Can anyone tell me if this is genuine VW? I emailed the seller, and his first reply was that it was aftermarket.  He then immediately replied again saying he made a mistake and that that first message was incorrect; it was in fact a genuine OEM part from VW.  It seems very cheap though...  http://www.ebay.co.uk/itm/151657607744?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Also, is this the loom I need? http://www.ebay.co.uk/itm/MFSW-High-Version-Cruise-Airbag-Wiring-Fit-VW-Jetta-Golf-MKV-Touran-1K0971584C-/181805778411?hash=item2a547805eb:g:Rv8AAOSwjVVVqK4A
CD module will be ok
Loom is not correct
for a skoda FL wheel it should start 3T0
Loom is not correct
Cheers mate, how much are they new roughly?
I believe airbag for three spoke and four spoke is the same so existing airbag should be fine.
airbag will be fine but to get the buttons to work will require either a new m/f loom or to modify an existing loom
Thanks, understood. I have the part numbers that I need, would ideally just like to source a 3 spoke vrs mfsw but I can't find anywhere with stock. Skodateile is the only place that lists it that I'm aware of, but they have no stock.
3T0 971 584 this is the loom for a FL mfsw
