Looking at a Fabia VRS mk II - few questions
These are factory fit wheels.. but good point I'll call Skoda & confirm what the bolts need to be.
Needs a new full set anyhow as the current ones are getting corroded.. want my 'new' car to be a stunning as possible!!
Lovely car! Really like the wheels too but they are definitely aftermarket.
  • Replies 79
  • Views 5.8k
  • I just took the plunge last week and got a 2010 Fabia VRS and love it, I was slightly put off by the oil issues, and from what I can gather mainly effect the CAVE engined cars which a 2010/2011 would
  • MidlifecrisisT
    MidlifecrisisT
    I've owned mine just over two years now and it's never missed a beat. 2011 CAVE mine is. Oil can be an issue but I kinda expect some usage due to the type of car. I'd say top up between 1/2 litres bet
  • Provisionally bought one
I know this car ;) fast little bugger! lol.... glad you're happy with it :)
Those are not Factory Fit White Gigaro on the car.
Andy had different wheels on.
Those are the same wheels it's wearing now, aren't they? Yes not Gigaro, but I thought the were fitted as new - will check this up!
Edited by evtilsley
As far as I am aware, all the vrs came from the factory with gigaro alloys as standard. I'm pretty much sure there were no other alloy options
That is correct Mk2 Fabia vRS come with Gigaro Alloys as standard, and options on Colours / Finish.
White Gigaro fitted as standard on a S2000, (the car in Question was a S2000 / vRS)
& is now on After Market wheels.
White, Dark Chrome, Black or Silver as Options or Standard Fit, and all these are Gigaro Alloys.
(Some did leave Dealerships with Trinity fitted, because they were swapped at Dealerships, not Skoda UK Approved though,
and some Ex Demos had Wheel Colours changed when refurbished.)
What tyres are on the car just now, are they 215/40 R 17's.   The non Standard tyre size?
The Alloys fitted are nice, and i do not think they are  the same off set as Gigaro.
Nice stance on the car.
What suspension is fitted as it is now, ?
Springs / Dampers and is there a Rear ARB fitted?
Edited by GoneOffSKi
Rubber is 215-40-17 tyres
Think it's factory shocks but stiffer, lower 40mm springs all round. Rear ARB.
Nice firm ride makes my little boy laugh!
I'll call Skoda asap; think they told me white alloys were on this when newly delivered car - but maybe not these ones.
Agree there are def not Gigaro as I park next to one with those & are very different! (see my 'friends at work' thread)
Those Wheels have nothing to do with Skoda, no point calling Skoda.
Andy fitted them or they were fitted when he got the car.
Best get Locking wheel nuts to suit,  people do still steal nice wheels.
Declare all mods with the Insurance, including the make of wheels, because people still steal cars,
including Skodas.
The Car was delivered as a S2000.
(White Gigaro Alloys fitted.)
The owner that was selling it before Andy bought it spoke to me about the car.
I only found out it was the car Andy had when i met up with him.
The car is far from standard and i was impressed with it.
Not an Oil user, but in the distant past it might have been, or thought to be....
(Someone not able to check the oil level properly, car running original Map type thing.)
Just use Good Oil,  5w 40 Full Synthetic to VW 502 00. Use Good Spark Plugs,  i suggest DENSO.
A good Oil Filter, Super Unleaded Petrol,  good brake pads, the correct Air Filter for the Intake Fitted and all should be good.
Stay away from Skoda Dealerships Workshops, their Diagnostics and Software Updates, not required,
& do not let them touch the DSG and all should be good.
EDIT.
Loving them.
http://briskoda.net/forums/topic/396667-works-friends
Heard from Andy.. They're Rota alloys
Yup re insurance gave them a lonnng list of modifications!  Take ages ringing around getting quotes !!!
Been practising my warm oil checking at home :)
Going to get it serviced by a REVO specialist www.mdmtechnik.co.uk/
Oh, what's an S2000?
Best just do a 'Cold Dip'.
 Sat on the flat, stone cold, and you want the Oil at least at the top of the Cross Hatch.
Better above that.
Then there is also another,  you can do a JaboZuma Check.
Do the Cold Dip. then
Open the drivers door, put the key in, start the car, stop right away.  the Oil should be down, the oil was pumped up to the Oil Filter.
This level will likely be identical to a Hot Check once you have at least got the indicated oil above 50*oC likely 5 miles or more, better to 80*oC Plus. So more miles,
Stop, wait a few minutes, 3, or 4 or 5, and dip it.
It is amazing how many Skoda / VW / Seat / Audi trained technicians seem unable to get at least 3.6 Litres in
and no more than 4 litres and check the level correctly.
'Warm' is no use as a check.
EDIT.
Loving them.
Is 5w 40 the best oil to use?, I've been using 5w 30
The Recommended Oil and that used at a Dealership is going to be VW 504 00  5w 30 Full Synthetic Long Life.
So if you get Free Services or are on Variable Servicing best go with that.
Some CAVE and less CTHE had Oil Use issues.
5 W 40 Full Synthetic helped some owners reduce Oil Use, and find that with good 5W 40 Full Synthetic OIl the engine runs a bit cooler
or when used hard the temp drops quicker back down to the ideal oil temps in the low 90's.
It is unproven and untested and just in my imagination as vxh26 will be along to tell you. Just my silly ideas.
But Castrol 5W 30 Long Life oil is sh!te when used in a Twin Charger.
Multi National / International Oil Producer and Worlds 2nd Biggest Manufacturer must know better than me,
personally i think the recommended oil is still sh!te.
I'm using casterol Edge 5W 30 as a top up, I have some oil usage but well below what is given as acceptable usage, is it worth changing to 5W 40?
GoneOffski what oil make do you recommend
If you are going Tracking, living in a hot country or the likes buy what suits that.
For me ASDA 5w 40 Full Synthetic to VW 504 00 is perfect, or from Tesco, or any other seller,
or Comma Oil.
After all they are all produced by Oil Refiners / Producers.
http://commaoil.com
(there is a passenger vehicle checker on the site.)
Mobil 1,  Fuchs etc etc are all produced by Oil Refiners / Producers and maybe you get what you pay for.
http://fuchslubricants.com/engine-oils
4 or 5 litres for £20 or less is what i pay and i change Oil regularly,
and buy Oil filters for £4.
(No point wasting money IMO.)
Used to use Comma Oil 5w 40 with my (sadly long gone) mental TVRs - its good stuff.
Lot cheaper than what the dealers suggested - Mobil 1
Cheers on the 'Rota' wheels.
I think i will have a set of wheels from them.
http://rotashop.co.uk
Just spoke to Rota & just ordered set of wheels nuts & locking ones
Cheers I'll move to comma once the edge is finished I managed to get 4 litres for £30 at costco so was happy enough with that
Is it OK topping up with a different viscosity?
It is if you are going to be changing the oil soon as long as it is Full Synthetic.
But then you should not need to be topping up much.
Maybe best stick with topping up with what is already been used to Service the car,
then when you Change the Oil and Filter use the different grade oil.
Amazon do five litres of Comma XTC5L XTech Fully Synthetic 5W-30 Oil for £20.
If you are buying 5W 30 Long Life for the Twincharger it is the Comma Prolife 5w 30
or Comma Oil.
http://commaoil.com
Typo? I didn't think there were any 5W/40 oils to 504/007 spec. I'd be definitely interested in using one if there were.
Edited by OzFabia
Yes a typo sorry,  5w 40  to VW502 00
