Various mk1 Octavia vRS sundries
If you see anything pictured (most is still available) let me know by PM. :)  Everything going really cheap as need gone asap.
The OP should get a job designing shop displays!
Got ecu Jase?
Got ecu Jase?
I do have one ECU, but I don't know its history.  It was going to go to my nearby ECU guru for analysis before I did anything else (will also get immob delete)
PM me if you are interested.  All I can confirm its an Octavia vRS ECU and nothing more :D
Edited by devonutopia
Also have a mk4 Golf black carpet I could do with getting rid of as well.
Don't suppose you have this piece behind the handbrake, mines missing
2ef763b354361b0b735ba9be34184061_zpsffzj
Should do. Consider it thrown in with your breather pipe :)
Cheers buddy
What sort of condition is the black carpet Jase?
Hi, wondering if the window motor in the 5th pic is the drivers door unit and if so does it have a part number I could check against mine.
I have a 2004 1.9tdi L&K and need the motor for the wiring connector and the female connector on the wiring harness but I don't know if all models have the same motor and wiring harness.
Thanks.
Is there a drivers door wiring loom in there somewhere?
Have u got the twitter triangles !?
Andrei
Sold sorry
Andrei
Yes, have a good pair of tweeter covers with tweeters in them
How much u after !? Are they in good condition with clips on them !?
Andrei
Bump
Andrei
Pics don't work for me but do you have shifter cables?
Bump
Andrei
Sorry didn't see this.  Upon checking they had gone :(  Sending me a message on here works better as I don't see thread bumps :)
I have a couple of 5 speed shifter cables / gearstick metal bits. :)
Have you got a rear wiper motor?
