Broken Engine Cover Vent Hose
Hello folks. I've used the forum many times before for simple fixes and it's always delivered the info I need – so thanks, all. But today, I've found an problem that I can't find any information about. I have almost zero mechanical knowledge, so please excuse me if this is a stupid question.
I've got a 2005 Mk2 Octavia 1.6 FSI. I removed the engine cover (which I've done successfully a few times in the past), but today I snapped the small plastic pipe that connects between the engine cover and the engine.
It's this part number 03C103558. Part 21 in this diagram: http://vagpart.com/skoda/octavia-oct-eu-2005-1z-5-000-001-10353-cylinder-head-cylinder-head-cover-cover-for-intake-manifold/#p-sko-03c103558
It's right in the middle of this image.
I've no idea what this actually does.
So, my naive question is – can I drive the car before I fit a new hose? Will it cause damage, or will I just lose some efficiency or performance? I have an important journey to make on Monday, before the new part will arrive, and could do with some advice about whether I'm in trouble or not...
  • Sponsor
Drive it with carefree abandon.  It just lets a little fresh, filtered air into the engine, as part of the crankcase ventilation system. All you'll be doing is letting unfiltered air in instead, for a day or two. The engine will not care, or even notice.
Phew, that's wonderful to know. Thank you!
wrap some decent tape around the break.  should be fine for a while.
