Car broken down told all 4 injectors.Help
Skoda Octavia 2005 tdi 1.9 diesel
OK so last night . I just got off a 20 mile motorway journey. The car started to appear to be accelerating when I was pressing the break. I pulled over and black smoke.
Another road user said he thinks it's the turbo.
When the rac man came he thought fuel injector as he heard a misfire. Anyway it was tied to a garage . I phoned this morning and they said it was all 4 injectors that will need to be replaced and a harness. Quoting £2031to fix. They said the only code that came up on the diagnostic machine was bar gauge.
They said they only use injectors from Skoda direct.
I phoned another mechanic and he said rwhy would all four injectors need replacing and the harness. Only because the reading was high on the machine doesn't mean all of them are below par? So would injectors show up on diagnostic machine?
I do have a warranty but will have to see what they say Monday. The other mechanic is saying at the worse mine can be refurbed or I can get recognition Ones.
Sent from my HTC One M9 using Tapatalk
Fuel injectors can be checked one by one. It costs something but if one of them is good then even then you will have saved money.
About what happened: sounds like so called diesel runaway (https://en.wikipedia.org/wiki/Diesel_engine_runaway) and it's turbo related. Read more about that and think whether it's your case or not.
I agree with jevpls - turbo is your start point, something is causing run-away (won't be the injectors or loom)
After this I really doubt if all injectors have failed at once, the injector wiring loom has been known fail and a cheap fix (shows up as injector problems)
If you do as the garage has said and just replace injectors/loom then you will have spent a lot of money and not fixed the underlying problem - which will happen again and possibly destroy your engine
Edited by bigjohn
Thank you for both replies. I racked my brains about ten days ago as this happened yesterday.
On cold start I noticed some white smoke coming out exhaust. It lasted for like say ten seconds and car was fine until this. Ran fine. Was serviced in December and mot was 15 of March and I trust the garage . The garage I have taken it too ...is not my usual.
And I was baffled when he said all injectors but only a bar pressure fault code using their machine. There was no warning lights when driving.?
I agree with other members, that not all the injectors would fail at the same time.
You probably could get one injector starting to fail, by seeing black smoke of unburnt fuel from exhaust.
Try another garage, have you a Skoda repair shop near you for them to do a diagnostic, rather than guessing or paying-out loads of your hard-earned money.
You could take off the injectors yourself, and take along to a diesel specialist to test for you..
Edited by giandougl
update. ok so all four injectors change, tank was contaminated. The faulty injector i was told was on cyclinder 4, however the garage have advised me to drive the car and the smoke...which is still there along with a misfire, may disappear after 500 miles, because they removed 10l of diesel and oil from the oil...tank.  There was never any black smoke, just white, theres still white with a not so potent smell. I have driven about 300 miles so far and i aint really seen much different seems to be a white smoke cloud wherever i drive and its worse when im waiting at lights etc.      They have also advised that they could be a cyclinder rod  that is bent on cyclinder 4 and that it could be hydrallic? Can anyone advise what i should do next, i have already made them aware that I am not happy with certain things but they said its all part of the diagnostic process.
As previously mentioned:-
"If you do as the garage has said and just replace injectors/loom then you will have spent a lot of money and not fixed the underlying problem - which will happen again and possibly destroy your engine"
You might need to consider that the first engine run-away has caused major damage - have you looked in turbo pipes for oil just to make sure?
Something doesn't sound right, although diesel in the sump oil sounds worrying and could be the cause of the run-away , It's possible with mis-fitted injectors - what is the cars history?
PS don't just drain off a bit - change the oil - it will be cream crackered
Edited by bigjohn
Is the 1.9PD the same set up for injectors as the vrs PD engine. If so, diesel can get past the seal into the engine. It's been mentioned on here quite a few times after the PD injector recall.
Edited by meta55b
I thought the 2.0 PD 170 engine in the vRS used different injectors to the 1.9 engines.
Sent from my D5803 using Tapatalk
The fuel tank was contaminated, how and what with?! or do you mean the oil tank, and if that, how has diesel got in there?! Very odd.
Oil in the fuel would suggest a borked tandem pump. I assume that the 10L was removed from the fuel tank as I can't see the engine could hold that much oil.
Edited by trundlenut
Indeed - https://forums.tdiclub.com/showthread.php?t=347305
Whatever happens when sorted still do another oil change though
Edited by bigjohn
Mine was leaking diesel into the oil, but there are quite a few examples of it happening the other way round.
At the OP - I assume the garage changed the fuel filter?
the garage changed oil and filter.
apparently they moved the oil from the engine??? so the oil tank was contaminated.
iam thinking next port of call is a leak test to be sure, i just dont want to waste money, i do love and want to keep the car. I just dont want to waste money if it is dead, but also dont want to change a new car. So i was thinking a leak test?
Again I can't how the engine could 10L from the engine, it would have filled the rocker cover.
Hopefully it was a duff Injector leaking fuel and contaminating the oil.
update.
.....because they removed 10l of diesel and oil from the oil...tank. ......
10 litres of oil from the oil tank?
Didn't know we had an oil tank on the diesels.
The engine capacity is less thank 5 litres......unless someone has seriously over-filled the engine.
ok the diesel was in the engine, iam going to another garage now, i want to say hanks for all your advice. I think i may need a new engine because it is making noise and things but I am gonna get other opinions before i spend .
update so after driving and doing test at a few places. The  consensus  is that their is a leak on one of the cylinders .Because diesel is still getting into the oil , after being drained and changed etc. So my next step is going to be a  new to me engine. I have done over 500 miles since the first repair the smoke has calmed down a bit but is still white and smells of diesel and the car is using way more fuel. I have sent almost double what I normally do in a week doing the same long journeys etc. It smokes more when accelerating.
Edited by skowillow33
