Octavia Mk1 display language change
I have been driving my car for several years now dealing with German messages in the display and am finally getting tired of it  :sick: .  I have tried pushing every button available but can't seem to stumble onto a menu that will allow me to change the language to English.
Any help would be greatly appreciated.
Have you got access to VCDS?
It should be possible.
http://uk-mkivs.net/topic/74400-warning-notice-display-change-languages/
if you have access to VCDS then you can change the language by the following
Select 46 - Central Convenience
and then Adaptation - 10
Channel 04
Use one of the following values
00001 German
00002 English
00003 French
00004 Italian
00005 Spanish
00006 Portuguese
00008 Czech
I take it the only way to change the language is to go into the ECS.  Unfortunately I don't have access to VCDS but will check around and see if I can find anybody with it.
Thanks for the lead.
To be fair, if you can't find anyone local with it, I'd just order a cheap clone VCDS cable from Aliexpress for £15.
On a mk1 Octavia you aren't going to run into any problems with a clone cable.
If you can't find anyone and you fancy doing a long trip to Pärnu, Estonia I'd be happy to do it for you
