Drum Brake Question
Hi all just a quick enquiry - I have just been on holiday and en-route the shoes on the near side began grinding.
Now home I am going to replace the shoes - my query is - do I replace the drums too whilst at it ???
Thanks in advance
It all depends on how bad the scoring is on the drums. They can be machined but only to a minimum thickness. Depending on how cheap the drums are is whether to replace them or not really.
That would depend on the condition and wear on the drums.
Personally i would just change the drums to discs brakes, not overly hard to do as everything is already on the axle for excepting the caliper carriers
Cheers & I think I will just change the drums too.
Also I think changing to disc is out of my capability - what would I need ??? Do you want to do it
You'd need new backplates, new brake pipes, new stub axles, new bearings, callipers, carriers, discs and pads. More than the cost of shoes wheel cylinders and drums being replaced.
Cheers I think I will just do drums & shoes
For a discs conversion
2 Handbrake cables
Discs and pads
Calipers and carriers
2 Splash shields
Or buy off a car that's breaking or take the complete axle and swap that way
No need to change stub axles or bearings as they are the same
Any Octavia I buy that has drum brakes are changed as a matter of safety as had a brown trousers moment when the clip retaining the brake shoe in place failed the piston on the slave cylinder popped off
Edited by sesachc
I did the drums, shoes, springs and cylinders all at the same time. Mostly as theyd never been touched in the preceding 170k...
2 Handbrake cables
Discs and pads
2 Splash shields
To change the backplates you have to remove the bearing and usually that means a new bearing. Depending on how badly the bearing is on the stub axle dictates if it needs replacing or not. I upgraded my rear callipers and discs to vRS discs and callipers on my tdi and had to replace the rear bearings and was lucky that I didnt need the stubs as the bearings were able to be removed from them.
Yup that's right, you do have to remove the stub axle in order to fit the splash shields and replacing parts while you do that is optional
