Hot Day... No AirCon!
Found a place who will run basic checks and regas for £25 so I'm going to try that first before doing anything else.
  • Replies 84
  • Views 10.2k
  • Breezy_Pete
    Breezy_Pete
    Yep, easy to see once any engine undercover is out the way.   Just checked and confirmed G65 location as above pic, by unplugging that connector while VCDS was on measuring block 2, Auto HVAC module
  • Sorry I might be operating under the delusions of knowledge imparted by drinking wine - but, the compressor control signal wiring might just be one of the two sets of connectors under the battery area
  • Breezy_Pete
    Breezy_Pete
    I'd guess that he 898 fault is a bust wire, as you suggest.   The G65 fault may go away when the other is fixed, not sure. It's the sensor that tells the HVAC module what the refrigerant pressure i
Yeah if you had a gauge set you could have checked the pressures yourself, for that price you might as well get it regassed.
0 bar would mean no gas if the sensor/wiring is OK. You probably have a compressor shut off code as well relating to low pressure in the system. Do you know when it was last regassed?
Edited by Dazza95
All gassed, no leaks ... Still no air con.
G65 seems to be culprit or wiring
  • Sponsor
If it was the wiring for the G65 then it would be short to ground, not low pressure / signal?
Ross-Tech says most likely low refrigerant pressure in system.
Maybe, but 0.0 seems remarkably low. Chances are that it needs some gas anyway though, unless you know it's been done in the last 5 years.
Not sure vcds would spot the difference between a bust signal wire and a real zero reading? You'd hope so, somehow. Might experiment later.
No voltage at G65 ... Running out of patience with this car and electrical faults!
Where does the G65 wiring go?
Errrr ...helps if I make sure multimeter is set properly!
12v at wiring ... :)
Sensor it is!
  • Sponsor
Wiring goes into scuttle area near brake servo i think.through firewall fromm there.
Edited by Wino
Off to buy new sensor :)
  • Sponsor
Fair play. :)
Fingers crossed this fixes it ... and work out how to get to the sensor to replace it! Looks tight in there ...
I assume I don't need to drain down system to replace? I'm sure I read somewhere this wasn't required?
  • Sponsor
Think I've read the same.
New G65 done ... No air con. Grrrrrr
Ok so ... Fault code has cleared ...
Compressor load on idle: 81%
5.8 bar pressure (G65)
Fans no workie...
Ok, so fans have been tested by shorting thermoswitch wires ... I get slow speed and fast speed depending on which way they are connected ....
Thermoswitch ?
  • Sponsor
Thermoswitch not involved when AC module brings on fans. Look to fan control module next. AC module grounds a couple of the thin signal wires to this unit, triggering the relays inside. Wiring info coming shortly.
Have you let g65 pressure go above 9 bar? Cos I wouldnt expect fan action before.
Edited by Wino
No not let it go above 9 bar ... Still no air con though.
Time to test fan control module then ... Appreciate the help and info. :)
D8901D4B-2FE2-4287-86CC-393ECED52BF8_zps
As it sits ...
  • Sponsor
Aircon should do stuff even without fan help, while pressure is low enough. Does the button light up? Got cabin fan running?
Left idling for a while and G65 doesn't go above 5.5 bar ...
Button lights up, switch on / off and compressor load drops from 80% to 0% ...
Cabin fan works on all speeds ...
Argh! Lol
  • Sponsor
So is the compressor doing any compressing?, Doesn't seem like it. The pulley hasn't sheared at the rubber coupling has it?
How do I check that fella?
  • Sponsor
Not 100% as I haven't looked into it or seen one where it's 'gone'. I think someone once described it as the pulley going round as normal, but the central shaft not rotating, not sure which end of the shaft can be seen. Will pop out and have a look now.
