Hissing sound while revving engine
My1.8tsi skoda octavia 2009 started making a wierd noise like a hiss under hard accelraion i did notice some drop in power although im not sure of that
I have no idea to check where the hoses are etc
Have clicked few pictures i see some leak of sorts near a tube
Please guide me
boost leak, maybe.
boost leak, maybe.
Please be a bit more specific
Is it due the leak to some pipe or sometuing inside the turbo?
Probably a turbo pressure hose thats split or a joint that has parted. Look for any oil around the turbo hoses and joints. Usually a sign of pressure leak.
I see oil around the hose catched with dust i think but car was fine untill yesterday afternoon it was after a pretty spirited drive this happend
Are we looking a huge cost or turbo issue by itself ?
Please see the pics link i posted of my engine and the leaks
Hissing sound after spirited drive definitely sounds like a boost leak.
You need to check the big air pipes coming off the turbo to the intercooler and back to the engine intake.
Hopefully just a split pipe which is cheap fix. Worst case is cracked intercooler/turbo/intake but that's much more unlikely.
Lee
This might help:
http://bfy.tw/6EHJ
Edited by mbames
This might help:
http://bfy.tw/6EGx
Would have been more helpful if you had put boost instead of boot.
Fixed that.
Lee
thanks for your response
jus asking did u check those images i send  u the oil catch around the black tube joints ? does this look like turbo sealant broken off ?
No sorry, I haven't received any photos.
The pressurised air pipes that run from the turbo to the intercooler and back to the engine intake contain compressed air and not liquid or oil so it's hard to see anything leaking.
Look at the turbo, big pipes come from the turbo to the front of the car to the intercooler (Looks like a radiator) and then big pipes back from that to the intake at the engine.
Get someone to rev the engine while you listen and feel for air leaks, you should feel air pushing out. Be careful not to put your hands near moving parts like belts and fans.
Lee
Lee
thanks  for your response, i couldn't figure out where exactly these hoses are ,don't u have to check for it under the car,is it ok to lift the car and rev it and try hearing for the tubes at the bottom?
heres the links for the pictures
http://postimg.org/image/j5b7dwgej/
http://postimg.org/image/3kguqnnd7/
http://postimg.org/image/g74l9cd1n/
The last two photos could be a sign of a boost leak, can you feel anything around that area when the engine is revved?
iam not sure i felt anything..
why is the oil there ? ITS BEEN DRE SINCE quite long  before this spooling sound started
the power picks up after higher revs i noticed .usually around 2 k rpm it used to start pulling but now it shows hesitation but once it crosses 3.5k it pulls and after 3 rd it pulls okay> this is what i felt
the issue was found to be broken diverter valve under the turbo ..
the o rings were broken giving irregular boost :(
Have you fixed it? It's a £50 part and just 3 fixings to remove it.
any links for the oem part available ?
is this the part number 06H 145 710 D
