P0136 02 Sensor Intermittent circuitry issue
Hi All,
I finally got rid of the engine check light after 2 years of it being constantly on.. It was the EGR that needed a serious clean. I was so happy!!
It stayed off for a month, and then yesterday came back on again :-( Ran the diagnostics through it and found that it is now logging P0136 02 Sensor bank 1 sensor 2 intermittent circuit issue. Is this a driveway fix and if so what part do I need?
I guess the connection is perished so it might be worth replacing the sensor rather than bodging it..
Iain
Quite a common fault 02 sensor wiring. Could be a few things, most common is an issue in the wiring loom under the battery area.
  • Sponsor
Which engine is in your car?
It's the 1.4 16v. Is it an easy sensor to find??
  • Sponsor
It's a pig to do without a four-poster and a hot spanner on standby, pay a fast-fit place to do it.
  • Sponsor
Agreed. I managed to remove one in-situ on the drive, but only 'cos it was recently fitted into a new cat section a week or two earlier, and I didn't immediately realise it was fooked by the move, no fault lights.  Getting it out of the original cat pipe ex-situ was awkward enough, I seem to remember putting the sensor in a vice and turning the whole pipe; maybe that's when I killed it! :D
Edit: But... before spending anything, check the wiring between sensor and the connection that's just out of shot in the bottom right corner of my pic above (assuming same set-up as on Polo), and the connector pair for water ingress and corrosion.
Edited by Wino
Brilliant, really good advice.ill check the wiring out this w/e
