access when battery is flat ?
4 hours ago, PetrolDave said:
I think you have crossed over LHD and RHD.
Semantics dear boy - semantics.  Clearing up my earlier statement, the Octavia design works well for European drivers (who drive on the right), but badly for UK drivers (who drive on the left); however, I understand the norms of LHD and RHD and I should have used those standard terms.
  • Replies 52
  • Views 38.5k
  • I questioned SUK on this as id you have a flat battery and the car is deadlocked you cannot operate the bonnet release........ They declined to answer....  I think you're just meant to leave it where
  • Just been trying this out so I'll know in future. RHD drive model and prising off the drivers door handle cover is easy using the key tip, there is a recess designed for it. The bonnet pull handle is
  • Don't know about you but my manual is kept in my car.   Which in the case of the OP is locked!
1 hour ago, ords said:
Why is the design bad for left hand drive cars?
But important semantics that have confused at least one member - ords.
You should be able to pull the bonnet release catch out just enough for it to scrape past the locked passenger door.
It worked for my Rapid anyway. Good luck
