Pre - FL 7p6 Bluetooth retrofit. Help please
Folks I'm just in the process of wiring up a 7p6 module. Car is in bits, front seat out and I don't know where to screw down the module. Any suggestions, there are some threaded rods in the floor but they don't look like they're spaced correctly to fit the box.
Help!!
Usually the box comes supplied with a foam cover which the module clips into, then it just velcros the whole lot to the carpet.
Aaaah bugger. Ok cool cheers.
Or self-adhesive velcro just on to the box and stick to the floor. Mine's not moved in 5 years
I've wrapped some Velcro ties around for now and velcroed it to the floor but I'll look for the foam cover to do a proper job
i fitted mine behind the glovebox and havent had any issues but as mike says it fits behind climate control too.
