8U0 955 559B VCDS default coding
Hi to all Skoda lovers & retrofitting geeks.
Would anyone of you, who owns an Octy 3 with automatic rain wiper & automatic headlights AND access to VCDS AND 8U0955559B RLFS sensor be so kind enought to check his default RLFS coding?
I retroffited this sensor (along with AUTO headlights switch) and all works fine, but I have problem sleeping because my sensor has AUDI options coded on byte 2 (02006C) and I have no Skoda options available in VCDS.
Thank you!
I hope this helps:
Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0004
   Serial number: 60868517
   Coding: 00885D
Thank you, it helps.
Interestingly is that I tried coding it to 06885D, too see if rain closing works even though it was said it doesn't work on this type of sensor and... IT WORKS!
My car is MY2016.
My car is MY2016.
Wow. Could you make a how to on the rain closing?.
Edited by KjetilRos
To repeat my steps fully, this is how it goes...
1. Coded RLFS to 07885D (07 also enables "Highway lights"):
- 09-Cent. Elect 》 Coding - 07 》(select RLFS from drop-down) 》 manually enter 07885D 》Do it!
2. Then I made proper adaptations at 09-Cent. Elect.:
- (15)-Access control 2-Regenschliessen_ein_aus 》active 》 Do it!
- (16)-Access control 2-Regenschliessen_art 》 Permanent 》Do it!
- (28)-Access control 2-Menuesteuerung Regenschliessen 》 active 》Do it!
3. Then I went Car 》Settings 》Factory settings, on MIB2 and reseted Lights, Mirrors and Wipers, Opening and closing. After that I checked if Rain Closing was enabled under "Mirrors and Wipers" (it already was) and also parametered all other setting that changed to defaults with Factory reset.
4. And last I coded RLFS to 06885D (changed my mind midway through about having "Highway lights" enabled):
- 09-Cent. Elect 》 Coding - 07 》(select RLFS from drop-down) 》 manually enter 06885D 》Do it!
That was it. Closed and locked the car with all 4 windows slightly opened, waited a minute and tapped with fingers on my windshield where RLFS is.. Windows closed!
Keep in mind I have 8U0 955 559B and not 8U0 955 559C RLFS
Where have you read that rain closing doesn't work with a 8U0955559B sensor?
I posted In February that it did work with this sensor on the O3 VCDS sticky?
Edited by andyvee
So this works on all my16?
It works with the 8U0955559B sensor which as far as I am aware was introduced MY16.5
  • 8 months later...
Hi Milan
I Have sensor 8U0 955 559 C, but rain closing not working.  :( Do not you know what the problem is? AutoWiping and Auto Light its works. ThankYou
How do you install VCDS on your car?
You don't, you install it on a Windows PC/laptop/tablet which you connect to the car via a lead that plugs into the OBD socket that is just above the throttle pedal.
18 hours ago, Chris_kn said:
Hi Milan
The rain closing is problematic on MIB2 cars. It works for me only first 90 seconds after locking the car, after that BCM goes to some sort of hibernate and it stops working. SO don't bother with it, even if it's not working from the start - you won't get much of thus function anyway.
In my sensor ( 8U0 955 559 C ) there is no auto rain closing function option. But Coming Home / Leaving Home does not work :(
Edited by Chris_kn
Do VCDS alternations void warranty?
No definite answer to this one. Some claim it does, some claim it doesn't (legally). It seems the common experience is that dealers don't make problems with this, but at the end it's at your own risk.
  • 11 months later...
Hi all,
I've installed the rain/light sensor 5Q0 955 547 A on my octavia mk3, do you know if the encoding is the same?
Edited by luisfdgon
