Hey!
I made to one of the Octavia model year 2015 change, which tested the functionality of DRL lights turn signal light is switched on (as shown below Aside) but the owner did not want the lights to work in this way, and I do not remember the original settings of these items. We tried to restore your settings to factory settings, but the problem was not resolved. The problem is that the 0-position and the AUTO position DRL lights are on, but the parking and low/high beams DRL is off. Does anyone know how these pre-mentioned points are the original settings?
LED Daylight off (one side) by Turnlight
Leuchte4TFL LB4-Lichtfunktion A 4 auf "nicht aktiv"
Leuchte4TFL LB4-Lichtfunktion E 4 auf "Blinken links aktiv (beide Phasen)"
Leuchte4TFL LB4-Dimmwert EF 4 auf 0
Leuchte4TFL LB4-Dimming Direction EF 4 auf "minimize"
Leuchte4TFL LB4-Lichtfunktion G 4 auf "Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)"
Leuchte4TFL LB4-Dimmwert GH 4 auf 127
Leuchte4TFL LB4-Dimming Direction GH 4 auf " 4 auf "maximize"
Leuchte5TFL RB32-Lichtfunktion A 5 auf "nicht aktiv"
Leuchte5TFL RB32-Lichtfunktion E 5 auf "Blinken links aktiv (beide Phasen)"
Leuchte5TFL RB32-Dimmwert EF 5 auf 0
Leuchte5TFL RB32-Dimming Direction EF 5 auf "minimize"
Leuchte5TFL RB32-Lichtfunktion G 5 auf "Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)"
Leuchte5TFL RB32-Dimmwert  5 GH auf 127
Leuchte5TFL RB32-Dimming Direction GH 5 auf "maximize
Did you use VCDS? If you did then VCDS saves a log file of the previous and changed values for every change you make to coding and adaptation channels.
AFAIK that's the default factory setting for the DRLs.
Edited by PetrolDave
Yes, i use the latest official VCDS program and the original cable.
Saves VCDS program logs the changes automatically or must save logs themselves?
if need to save themselves, how to do that? Where VCDS save These logs?
The car owner said, that before the change the drl-lights were on in every light positions that there is in the car.
Does it get fixed, when we code drl lights again to the car, or is there some other solution for the problem?
By default VCDS saves the log files in the folder \Ross-Tech\VCDS\Debug. One is called AdpLog and one called CodingLog
In recent versions it saves them as a .csv file with all the changes listed by date & time.
Here is an example CodingLog.csv:
Address 17,5E0 920 950 ,recoded (Long Coding),from,27A40A002590A60001886A011000000000000000,to,27A50A002590A60001886A011000000000000000,(73430/790/00120),Sunday,07,August,2016,13:34:26:40444
Address 17,5E0 920 950 ,recoded (Long Coding),from,27A50A002590A60001886A011000000000000000,to,27A50A002590A60001887A011000000000000000,(73430/790/00120),Sunday,07,August,2016,13:35:17:40444
Address 52,5Q4 959 592 C,recoded (Long Coding),from,00150020D001040000001100,to,00150020DC01040000001100,(73430/790/00120),Sunday,07,August,2016,13:37:28:40444
Address 08,5E0 907 044 K,recoded (Long Coding),from,02110004000100011005000000101000,to,02110004000100011005004000101000,(73430/790/00120),Sunday,07,August,2016,13:46:16:40444
Address 09-01,5E2 955 119 ,recoded (Long Coding),from,065DDD,to,064DDD,(73430/790/00120),Sunday,07,August,2016,13:47:29:40444
Address 09-01,5E2 955 119 ,recoded (Long Coding),from,064DDD,to,0E4DFD,(73430/790/00120),Sunday,07,August,2016,13:48:23:40444
Address 19,5Q0 907 530 AC,recoded (Long Coding),from,030100042F085700EF000258080F00010001050000000000000000000000,to,030100042F085700FF000258080F00010001050000000000000000000000,(73430/790/00120),Tuesday,09,August,2016,15:42:17:40444
Address 09-02,5Q0 955 547 A,recoded (Long Coding),from,00885D,to,06885D,(73430/790/00120),Tuesday,09,August,2016,15:47:02:40444
Address 08,5E0 907 044 K,recoded (Long Coding),from,02110004000100011005004000101000,to,02110004000100011005004010101000,(73430/790/00120),Friday,12,August,2016,13:34:52:40444
Address 52,5Q4 959 592 C,recoded (Long Coding),from,00150020DC01040000001100,to,00150020D001040000001100,(73430/790/00120),Wednesday,24,August,2016,10:57:17:40444
Address 08,5E0 907 044 K,recoded (Long Coding),from,02110004000100011005004010101000,to,02110004000100011005004000101000,(73430/790/00120),Wednesday,24,August,2016,11:00:34:40444
Address 44,5Q0 909 144 R,recoded (Long Coding),from,8303,to,8703,(73430/790/00120),Wednesday,24,August,2016,11:01:37:40444
Address 52,5Q4 959 592 C,recoded (Long Coding),from,00150020D001040000001100,to,00150020DC01040000001100,(73430/790/00120),Wednesday,24,August,2016,11:34:00:40444
And here is an example AdpLog.csv:
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,adapted from,not active ,to,active ,Sunday,07,August,2016,13:41:42:40444
Address 09,5Q0 937 084 AJ,channel ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,adapted from,not active ,to,Daytime running lights ,Sunday,07,August,2016,13:44:44:40444
Address 09,5Q0 937 084 AJ,channel ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,adapted from,not active ,to,Daytime running lights ,Sunday,07,August,2016,13:45:16:40444
Address 09,5Q0 937 084 AJ,channel ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,adapted from,not active ,to,Abbiegelicht links ,Sunday,07,August,2016,14:34:28:40444
Address 09,5Q0 937 084 AJ,channel ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,adapted from,not active ,to,Abbiegelicht rechts ,Sunday,07,August,2016,14:35:02:40444
Address 09,5Q0 937 084 AJ,channel ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,adapted from,not active ,to,Nebelschlusslicht wenn kein Anhaenger gesteckt ,Sunday,07,August,2016,14:37:04:40444
Address 09,5Q0 937 084 AJ,channel ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,adapted from,0 ,to,100 ,Sunday,07,August,2016,14:39:09:40444
Address 09,5Q0 937 084 AJ,channel IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,adapted from,Low beam ,to,Fog light ,Sunday,07,August,2016,14:40:30:40444
Address 09,5Q0 937 084 AJ,channel IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,adapted from,not active ,to,active ,Sunday,07,August,2016,14:46:56:40444
Address 5F,5E0 035 874 A,channel IDE00346-Summertime-automatic,adapted from,manual ,to,Europe ,Tuesday,09,August,2016,15:38:34:40444
Address 5F,5E0 035 874 A,channel IDE03581-ENG117688-Vehicle function list CAN-Driving_school,adapted from,Not available ,to,Available ,Tuesday,09,August,2016,15:40:25:40444
Address 5F,5E0 035 874 A,channel IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,adapted from,not activated ,to,activated ,Tuesday,09,August,2016,15:41:01:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,adapted from,not active ,to,active ,Tuesday,09,August,2016,15:45:31:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG125656-Access control 2-Regenschliessen_art,adapted from,once ,to,Permanent ,Tuesday,09,August,2016,15:45:55:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,adapted from,not active ,to,active ,Tuesday,09,August,2016,15:46:24:40444
Address 09,5Q0 937 084 AJ,channel ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,adapted from,not active ,to,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,Friday,12,August,2016,13:40:44:40444
Address 09,5Q0 937 084 AJ,channel ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,adapted from,not active ,to,Parking light right ,Friday,12,August,2016,13:41:11:40444
Address 09,5Q0 937 084 AJ,channel ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,adapted from,not active ,to,Nebellicht links ,Friday,12,August,2016,13:44:17:40444
Address 09,5Q0 937 084 AJ,channel ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,adapted from,not active ,to,Lichthupe generell ,Friday,12,August,2016,13:44:38:40444
Address 09,5Q0 937 084 AJ,channel ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,adapted from,0 ,to,127 ,Friday,12,August,2016,13:45:06:40444
Address 09,5Q0 937 084 AJ,channel ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,adapted from,not active ,to,Nebellicht rechts ,Friday,12,August,2016,13:45:58:40444
Address 09,5Q0 937 084 AJ,channel ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,adapted from,not active ,to,Lichthupe generell ,Friday,12,August,2016,13:46:17:40444
Address 09,5Q0 937 084 AJ,channel ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,adapted from,0 ,to,127 ,Friday,12,August,2016,13:46:39:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,adapted from,not active ,to,active ,Friday,12,August,2016,16:24:48:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,adapted from,not active ,to,active ,Friday,12,August,2016,16:25:02:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,adapted from,not active ,to,active ,Friday,12,August,2016,16:26:18:40444
Address 09,5Q0 937 084 AJ,channel IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,adapted from,not active ,to,active ,Wednesday,24,August,2016,10:59:02:40444
Address 5F,5E0 035 874 A,channel IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,adapted from,not activated ,to,activated ,Wednesday,24,August,2016,11:35:45:40444
Address 5F,5E0 035 874 A,channel IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,adapted from,not activated ,to,activated ,Wednesday,24,August,2016,11:36:25:40444
Address 09,5Q0 937 084 AJ,channel IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,adapted from,not active ,to,active ,Friday,26,August,2016,11:34:39:40444
Big thanks for the information. :)
This is the first link in the VCDS O3 Sticky index ....
Which is where I got the information from to do this change on my Octavia :notme:
It seems V3lmu's problem was that he didn't make a note of the previous settings, and didn't know about the logs that VCDS keeps either - so when he tried to revert he couldn't :rofl:
