2005 Octavia Mk2 Ambiente rear parking sensors
Surely you mean from neutral to reverse?
Just checked with your reg number:
SKODA OCTAVIA ELEGANCE FSI
So definitely an Elegance. It almost sounds like a problem with the communication to the module. A scan with VCDS may shed some light on it.
If you changed the module I'd suggest it's a coding issue.
I've changed my rear module to a front and rear one and without the correct vcds coding it won't work.
Also if any part is faulty it won't function either.
A vcds scan will tell you.
Edited by tubbytommy
Nope from reverse to neutral only
Hi mate.
Did you resolve this in the end. I've got exactly the same symptoms with my car and would be interested to know what it was in the end. Assuming you've fixed it that is!
