Front wipers are not working properly
Hello!
I have problem with my Front wipers. When I change windscreen wiper control for 1st speed level nothing is happening. When I change for full speed windscreen wiper it is starting. I assume that there is problem with windscreen relay.
I want to change bot don't know where it is and how to change it ?
I took some pictures of relay panel maybe you will be able to help me ?
My car is Skoda Rommster 2008 1.2 htp.
Please check those pictures:
IMG_20161112_141554.jpgIMG_20161112_144129.jpgIMG_20161112_144146.jpgIMG_20161112_144200.jpgIMG_20161112_144256.jpgIMG_20161112_144331.jpgIMG_20161112_144359.jpgIMG_20161112_144410.jpg
Edited by Gizmo68
  • Sponsor
I think the wipers are controlled by relays inside the 'vehicle voltage control module' J519, soldered onto the circuit board.
However, it's not clear to me whether this is valid from how you describe the problem, but if it is the intermittent operation that isn't working, but continuous operation is OK, check that your bonnet/hood is closed fully. If your car has a microswitch that detects bonnet opening, it will disable the intermittent wiper function if not closed fully.
Of course my hood is fully closed :). The issue must be somewhere else.
Maybe the hood microswitch is faulty? (If it exists)
Edited by bryanb
Do you have auto wipers?
If so the 1st position will only work when the sensor detects rain on the screen.
no I don't have autowipers
Get the car scanned then, it could be a faulty switch as they are not unknown to fail, especially as the wipers actually work... just not in all positions.
My VAG Errors codes:
13642 Unkown code error not authorized
14645 Unkown code error not authorized
13363 Unkown code error not authorized
16672
12339 Unkown code error . Too big refractoriness
19311 Unkown code error not authorized
26223Unkown code error not authorized
29799 Unkown code error not authorized
29409 Unkown code error not authorized
8224 Unkown code error not authorized
12336 Unkown code error not authorized CAN can no signal
0 Unkown code error
 constant value on exit or short circuit to ground
Edited by korbielow
Not overly helpful though are they, can you get someone with VCDS to scan the car?
I've got only VAG... :(. I try to find someone who has VCDS.
Edited by korbielow
