Diesel fuel filter change
I have a skoda fabia 1.6 tdi cr and i wish to change the fuel filter. It is a sealed canister with 2 pipes on the top. If I clamp the pipes at the filter before removing from filter then fill the new filter with fuel and reconnect and undo the clamped pipes. will I get away with out bleeding the system. I am thinking of my hpfp.
thanks
In a nut shell, yes.
Aslong as you fill the new filter up properly, prime the system by cycling the ignition on and off a good few times waiting 5 seconds on each turn of the key, it will be fine.
Exactly as said,took a little spinning over and stalled once or twice but soon settled down and ran sweetly.
To me it's surprising the difference it makes and a ten minute job.
Pre fill the filter (either diesel or injector cleaner, I'm not getting into that argument), then floor it when you start it, back off a bit, but keep the revs reasonably far up for about a minute.
 as my engine is a TDI CR is turning the ignition on and off priming the system?
The old engine (non CR ) you could get away with this. I am unsure now!
Yes exactly the same. Mine is also CR engine
Thank you :D
