RNS 315 Retrofit. No phone, and no clock synch
fabia220
Hi guys, new here so apologies if this has already been covered and I can't find it.
I'm trying to integrate a Skoda Amundsen RNS315 into my daughter's 58 plate Fabia.  It's a late head unit with bluetooth on board, and mostly it works, but the phone integration doesn't and it displays a few other quirks courtesy (I think) of the ECU not knowing it's there.  I thought I had all the kit I needed to fit it properly, but it seems I was a bit previous on that!
I have installed a new amplified DAB/FM aerial, a pukka VAG phone mic that snaps into the roof console, plus a GPS aerial.  Not the quickest job in the world, but all went together fine.   Getting the right fakra connectors and converters was a bit of a nightmare, but other than that no problem.  The radio, CD and SD card sound fantastic even on the stock speakers, DAB works great, satnav works, but...  the phone button does nothing apart from mute the speakers, the clock is wrong and the satnav is in km.  The latter two issues cannot be manually changed, they are synched to the car by the ECU if the RNS 315 is properly integrated which clearly mine isn't.  There are a couple of other items of weird behaviour too...  The unit does not switch off when the ignition key is removed, but it does turn itself off after about half an hour's driving.  This suggests that the power wiring is wrong, but the loom looks completely standard and the old radio/CD behaved properly.
I have the full VCDS software, but it doesn't seem to allow access to any of the relevant modules and Ross-Tech tech support were, let us say, disappointing.  Does anyone know how to get this unit to work, or is the car simply not new enough to accept it?  This was Ross-Tech's take on it, but I'm not convinced.  The vehicle scan is shown below - any guidance or advice gratefully received.  I only have a hex bus connector for my VCDS software (fine for my own 2007 Fabia VRS SE) but I'm wondering if I need to upgrade to a CANbus interface for the MkII Fabia?
Saturday,05,November,2016,19:20:06:05914
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: TMBBH25J083164616   License Plate:
Mileage: 46760km-29055mi   Repair Order:
Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBBH25J083164616   Mileage: 46760km-29055miles
Address 01: Engine        Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 023 B
   Component: SIMOS91 1.2l 4V     1891
   Revision: --H04---    Serial number: SKZ7Z0H4829331
   Coding: 0000071
   Shop #: WSC 13765 790 00000
   VCID: 1E3D0E51CAA0CFCE6C-51B2
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
   Part No SW: 6R0 907 379 C    HW: 6R0 907 379 C
   Component: ABS 8.0 front   H05 0002
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002100
   VCID: 3E7DEED16A60AFCE4C-51B2
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 5J0 820 045
   Component: Klimaanlage        X0850
   VCID: 62C57AA1EE58AB2E08-51B2
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E7DEED13A60AFCE4C-5196
2 Faults Found:
01304 - Radio
            49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: QN AIRBAG VW51 Q5   0010
   Coding: 20814
   Shop #: WSC 13765
   VCID: 2C59D499DC1C2D5EF2-5196
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 910 B
   Component: KOMBIINSTR.    V2823466
   Coding: 17403
   Shop #: WSC 13765
   VCID: 264D26B1C2F0170E24-51B2
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000E GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70E100E930B409BE8E-51B2
1 Fault Found:
01304 - Radio
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2823466
   Coding: 17403
   Shop #: WSC 13765
   VCID: 264D26B1C2F0170E24-5196
   TMBBH25J083164616     SKZ7Z0H4829331
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10140
   Shop #: WSC 13765
   VCID: 6DDF199D2786E456A5-51B2
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 5J0 959 433 A
   Component: 03 Komfortgerát     0001
   Coding: 00019
   Shop #: WSC 13765
   VCID: 3167C5EDFB3E40B6C1-4B64
End-------------------------(Elapsed Time: 03:25)--------------------------
You should update your VCDS first thing. Although I suspect that could be why you found Ross Tech "disappointing".
After that, your car is most likely too old to have the required level of Canbus required for the functions you want, and also I suspect the Fabia runs DDP protocol while the Amundsen + is BAP protocol. They'll never talk to each other.
I have a 2007 07 plate Roomster Scout with RNS315 fitted.
I have time sync, lights sync ok, the navigation works fine (didn't when I trial fitted our RNS510).
Neither directions, nor music show on the maxidot - and the car doesn't turn off with the ignition (and turns itself off every 30 mins)
There is a fix - search Kufatec for their 1.6 --> 2.0 canbus adapter
Thanks for that B1ackb1rd.  Sounds like you have some very relevant experience of the issue.  I'll get onto Kufatec first thing.  This car doesn't have a Maxidot display so thats' one problem I don't have to worry about.  Have you fitted one of these Canbus adaptors or did the RNS315 work OK apart from the on-off issues?
Actually .... I've just remembered mine is an RNS310 not RNS315, this will probably be the reason I have more integration with my 2007 Roomster.
Both 310 and 315 are brilliant units, much quicker than the RNS510 - I have mine set up with the navigation CD in the slot and a 64Gb SD full of mp3 music (all of my itunes is converted to mp3)
I may be wrong, but I THINK another module is required for full bluetooth integration
The unit stacks up as a 315 with integral Bluetooth according to all the checks I can make (mac address etc) so I'm reasonably sure it's genuine, but as you say, stickers can be changed!  The fact that it has DAB on board confirms it's a high spec unit too. There is plenty of stuff out there about 'enabling Bluetooth' on the car itself before it will work on the head unit, so I'm hoping that if they can be made to talk to each other all will be well.
I'll let you know!
The fact it has DAB means it is an Amundsen + unit, and as such is BAP protocol. The Amundsen doesn't have DAB and is DDP protocol which is why Blackbird has had some success with making his work. I'm not sure there's much mileage in this attempted retrofit to be honest.
No ignition live on them as such. The unit wakes up and sleeps via signals from the Canbus system.
My RNS310 switches on/off entirely on the button, it takes the time and lighting signals from the car.
Can someone explain the ign/perm live switching please, I'm keen to give that a whirl
There is no ignition/permanent live switch trick which will help you with the issue of the unit going to sleep. The only way to keep the unit awake is for the canbus system to tell it to stay awake.
Edit: As I've said before, you can buy a canbus emulator which will allow the unit to function correctly with ignition on / off, but when I mentioned it you told me that using your finger every 30 minutes was cheaper...
Edited by Rustynuts
Every day is a school day..  :D They are not like the old skool ISO connectors due to CanBus then...
Edited by DamoR
Thanks for all the feedback.  It all seems to boil down to whether some kind of CANbus simulator is going to do the trick or not.  Thanks to Rustynuts I now understand that the on/off problem, and it seems feasible that a black box of some kind can trick the unit into thinking it has a proper CANbus connection so that this aspect at least works as it should.  However, there is also the issue of the clock and the km satnav, plus the main problem which is that the phone integration doesn't work, and it's harder to see how a CANbus 'trick' is going to fix that lot.  I agree with Rustynuts that it's highly unlikely that the car and the radio can be persuaded to talk to each other, so I suspect it comes down to how comprehensively the RNS unit can be fooled by an add-on item.  I am in correspondence with Kufatec, the supplier recommended by B1ackb1rd, so I'll let you know how I get on.
  • Like 2
I don't think a Canbus emulator will cover all the options here mate. It might be possible for the canbus emulator to convert 1.6 signals to 2.0, but nothing will address the DDP/BAP protocol mismatch.
For it to work correctly you need signal inputs from the wheel speed sensors, steering angle sensors, and possibly others as well so that the unit can operate outside of GPS signal (like going through a tunnel). Also it needs these to calculate when you're actually moving to route correctly, otherwise the voice announcement will keep saying "Guidance will start when you join the highlighted route, even though you're on it and driving. To get the sat nav and phone functions on the dash will not be possible due to the DDP/BAP mismatch which can't be addressed by a CAN emunlator, and there'll be other issues no doubt.
Edited by Rustynuts
My RNS310 gets a speed signal, the correct time and lighting from the car - it's just the turning off after 30 mins that does my head in.
I have maxidot, but I think I'll need a MFSW to get into the MFD menus to see whether mapping, music etc is read also.
(Surely BAP/DPP settings for these units are in the VCDS menus? However I'm sure you need the unit in a Golf mk5 platform Golf/Octy/Touran etc with canbus 2.0 to be able to access this)
